Need some info... -
post #1 of 4 Old 01-30-2008, 07:36 PM Thread Starter
Need some info...
So I have this paper to write for a manufacturing processes class. I have to take a part and look at the way it is conventionally made and compare it to making it in a "non-traditional" way. I chose to look at the oil pump gears in a 4.0L motor. I assume they're made through cold extrusion (pushing metal through a die to form the gear shape) and I am going to suggest they be made with wire E.D.M (electrical discharge machinging).
What I'm looking for would be anyone that would have a contact for an operator or engineer that has had anything to do with extrusion molding and I'm looking for any information regarding the metallurgy of the gears or even just the name of the company that would have manufactured those gears.
This paper needs a lot of details and it sucks.
joshs1ofakindxj is offline
post #2 of 4 Old 01-31-2008, 10:42 AM Thread Starter
anybody know anything?
post #3 of 4 Old 01-31-2008, 11:29 AM
alwaysready's Avatar
theres prolly only 2 people in the us that would know that for the 4.0 liter.
maybe 1 in china too,(aftermarket).
And i think extruding and cutting off the gears would be alot quicker.( i could be wrong)
it would be less waste versus EDM cutting out of a sheet..
3.5" Rubicon Express lift OME shocks
31" Mtr's on Moabs
Warn Winch bumper
Smittybuilt Winch
Aj's Super Rock Rails
Black XJ on Moabs Club Member #1 :D
alwaysready is offline
post #4 of 4 Old 01-31-2008, 06:16 PM Thread Starter
Not EDMing out of a sheet but using a 40" long piece of round stock or a someting shorter than that and cuting the gears into that then cutting to length. There is material waste from turning the ends of the gears to get them flat after cutting them to legth after extrusion and I'm sure cutting the gears to length with wire EDM would be beter but I don't know about the gear cutting waste. Also consider that the wire EDM will cut the ears more accurately and you can market them as "high performance"
In order to be able to post messages on the forums, you must first register.
Need info, looking at getting an XJ happymudder10 XJ/MJ Cherokee Non-Technical Forum 7 07-10-2009 07:07 PM
looking for info lifted92xj XJ Cherokee Technical Forum 5 01-21-2008 05:51 PM
Need Info. XJHERO XJ Cherokee Technical Forum 3 11-19-2006 06:48 PM
looking for a XJ need info MontyWilco XJ Cherokee Technical Forum 3 10-24-2006 05:05 PM
Going from TJ to XJ...need some info abacus6 XJ Cherokee Technical Forum 29 02-11-2006 07:15 PM
