Need some help with lift and transfer case questions.. - JeepForum.com
post #1 of 3 Old 10-30-2011, 11:49 PM Thread Starter
Happypwnstar
Im planing on getting a 4inch IRO long arm lift i know the basics around it well most of them i need help info on the transfer case. I know i can ether drop the TC or can get a SYE and CV drive shaft. I need more specifs though. Like if i were to go the drop i would need to angle the axle...well i dont know about a 4inch lift if i would. That aside I rather just go the SYE path so what else do i need and/or need to do? From the ground up all the detail possible would be great.
Happypwnstar is offline
post #2 of 3 Old 10-30-2011, 11:57 PM
Wearingthin
Most likely the TC drop won't be enough. It depends on the jeep though. I used a TC drop and I still get vibes around 45-55mph.
If you go the SYE path, either full or HnT, you'll need the CV style shaft like you said. For best results you want the angle of the rear pinion to be in line with the shaft itself, or a couple degrees down to compensate for the changes when apply power to the axle
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #3 of 3 Old 10-31-2011, 01:03 PM Thread Starter
Happypwnstar
Another Issues im confused on.
Do i need a front and rear drive shaft and/or SYE if i lift it or just the back then the TC drop will take care of the front?
drive shaft , lift , transfer case
Transfer case Questions 350zmarty XJ Cherokee Technical Forum 5 02-05-2011 02:49 AM
Transfer Case Questions panamah_r3d XJ Cherokee Technical Forum 3 11-26-2010 04:45 PM
Transfer Case Questions Red-Jeep90 XJ Cherokee Technical Forum 6 05-18-2010 12:54 PM
96 (231) Transfer case questions dedmete XJ Cherokee Technical Forum 0 05-06-2009 12:50 PM
Transfer Case Help/Questions MoochsXJ XJ Cherokee Technical Forum 2 02-19-2006 10:59 AM
