Need some advise. - JeepForum.com
post #1 of 4 Old 03-07-2012, 12:23 PM Thread Starter
sskinner
Need some advise.
OK looking for fog light switch that have print on them (I.E. foglight and maybe a fog light logo)
I has seen daystar switches but I have not found one that has print on them but I know they are out there as I have seen them before.
Also want something that will fit in the OEM location.
EDIT: also will be needing a relay what size should I go with?
sskinner is offline
post #2 of 4 Old 03-09-2012, 06:28 PM
BlueRidgeMark
1994 XJ Cherokee
Try an RV supply place for switches.
Relay? Depends on the fog lights. What wattage?
BlueRidgeMark is offline
post #3 of 4 Old 03-09-2012, 08:03 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Get an OEM Cherokee switch at the junkyard, at the Dealership, or at RockAuto.com.
Look up the formula and do the math. A 30-50 amp relay should be big enough.
CJ7-Tim is offline
post #4 of 4 Old 03-09-2012, 08:26 PM
wsar10
2003 WJ
You should always use a relay for fog lights, using a lo-beam 12v line to run to a switch and than to pin 85 (coil pin) of your relay.
A 30 amp relay will do, this will give you the capability of "up to" 360 watt lighting which is more than adequate for fogs.
I have seen small decals for switches..... IIRC maybe on EBAY.
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
need advise 3299race XJ Cherokee Technical Forum 2 04-19-2011 10:48 AM
Need a little help/advise wdswgn XJ Cherokee Technical Forum 4 12-22-2010 04:18 PM
XJ advise quick66ss XJ/MJ Cherokee Non-Technical Forum 2 03-05-2010 04:34 PM
Advise on XJ buy BenBru23 XJ Cherokee Technical Forum 16 12-15-2009 07:46 PM
need some advise yankee07 XJ Cherokee Technical Forum 4 09-25-2005 06:41 PM
