Need to replace the alternator and thermostat... - JeepForum.com
post #1 of 12 Old 08-18-2010, 06:10 AM Thread Starter
Yojimbo
I need to replace the alternator and thermostat in my 92 Cherokee Laredo. Can anyone point me to any threads or links that will give me instructions and helpful tips on how to do these replacements?
I will probably be getting the alternator from Advanced Auto or AutoZone. Are there any particular brands or models that are reccomended? Which ones should I avoid?
I will probably also change my upper and lower radiator hoses as well. When I purchased the upper and lower hose I only got to larger diameter hoses. Now I see there is a smaller diameter hose attached next to the upper radiator hose on the thermostat housing. What is this hose called and what size is it?
Thanks!
Yojimbo is offline
post #2 of 12 Old 08-18-2010, 06:33 AM
portcityXJ
1995 XJ Cherokee
Both are just this:
Unbolt
Replace
Just make sure you have the t-stat facing the right way. Pay attention to the old one when you take it out for orientation.
I approve this message.
Originally Posted by EricRollerSkate View Post
Do they come in any other varieties besides crap?
portcityXJ is offline
post #3 of 12 Old 08-18-2010, 06:40 AM
bmyohn
Youngin'
bmyohn's Avatar
Replacing you thermostat is very easy, its located at the top of the block at the front of the motor. Just about any brand from the major brand auto parts stores will do. I replaced my 210* thermostat for a 195* one and haven't had any problems. I believe the thermostat attaches with two bolts, just be sure to clean the gasket mating surface really well before re attaching it.
As for the alternator, its located on the passenger side of the block at the bottom of the engine bay. Its easily reach from below the jeep. (You may have to remove you drip shield if you still have the rubber liner from the factory.) The alternator itself is held on by three or four bolts. But to get the alternator out you will most likely have to remove the thin metal bracket that attaches to the block. To get the alternator to come all the way out you may have to loosen the belt to get the alternator out. Then just unplug it and remove the grounding wire. Should be good to go. Replacing your alternator and thermostat will most likely take a few hours, but you will learn alot doing it.
A word of advice on the alternator, buy an alternator that comes with a lifetime warranty. Since our alternators are located so low in the engine bay, they take alot of abuse from water, mud, snow, rocks, etc. So get one that you can take back and replace easily.
-Brendan
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #4 of 12 Old 08-18-2010, 10:10 AM Thread Starter
Yojimbo
Thanks for the replies!
Are there any special tools needed to do these jobs? Does anyone know what size bolts are used on the alternator and thermostat housing?
Yojimbo is offline
post #5 of 12 Old 08-18-2010, 01:20 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Buy good quality parts from O'Reilly or NAPA. Advance and IdiotZone sell cheap parts. A lifetime warranty on a cheap part isn't much good if you spend the rest of your lifetime running to the parts store to exchange your now dead cheap part for another one.
CJ7-Tim is offline
post #6 of 12 Old 08-18-2010, 01:35 PM
menace2
Disconnect the positive battery cable before you remove the alternator. Otherwise you may be arc welding with the big wire.
menace2 is offline
post #7 of 12 Old 08-18-2010, 02:20 PM
tangofox007
Disconnecting the ground cable is the "industry standard" procedure.
tangofox007 is offline
post #8 of 12 Old 08-18-2010, 02:51 PM
menace2
Yeah, but some people don't know that. Don't want him to learn the hard way.
menace2 is offline
post #9 of 12 Old 08-18-2010, 02:51 PM
dennis461
1991 XJ Cherokee
battery comes out first
1991XJ here.
I've found the alternator easier to get out by removing the battery and battery tray.
Yes, unbolt wires from underneath.
But there was no way mine was coming out from under and with 6" lift.
dennis461 is offline
post #10 of 12 Old 08-18-2010, 04:45 PM
tangofox007
Allow me to rephrase my previous statement:
post #11 of 12 Old 08-18-2010, 05:02 PM
menace2
Righto. Ground cable first gives less chance of sparking/arcing as the clamp is removed. Duh on me.
menace2 is offline
post #12 of 12 Old 08-18-2010, 06:20 PM
Carves
Just out of interest ......
How did you end up with a 210' thermostat in there ???
Carves is offline
alternator , instructions , thermostat
is the 2.5 diesel alternator the same as the 4.0 xj alternator LOIIIIIIIOJ XJ Cherokee Technical Forum 0 06-15-2009 07:28 AM
Need to replace the alternator, where do I go Rescue XJ XJ Cherokee Technical Forum 7 11-06-2008 11:37 PM
Big question: replace engine or replace Jeep? SoloHiker XJ Cherokee Technical Forum 10 03-19-2007 06:09 AM
Flushing Radiator, should I replace the thermostat also? 140k Iwantawrangler XJ Cherokee Technical Forum 5 05-18-2006 10:59 AM
Someone explain to me how to replace the thermostat.... mdoug445 XJ Cherokee Technical Forum 8 11-20-2005 04:27 AM
