Need to reattach fender flare 93XJ - JeepForum.com
post #1 of 3 Old 07-24-2009, 08:05 AM Thread Starter
WoodyinTroy
1993 XJ Cherokee
I took off my rear fender flare last night to do some repair work on the rusted out rocker panel and all of the bolts snapped off the metal mounting brackets. My questions are:
1. Do I need the 3 metal mounting brackets
2. Could I use zip ties to hold it on
3. If zip ties are not an option what nut/bolt setup is the best to keep them on.
Leaving for a wheeling vacation tomorrow (Saturday) AM so I don't have a lot of time to shop for parts.
Thanks in advance for answers.
WoodyinTroy is offline
post #2 of 3 Old 07-24-2009, 08:59 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can drill out the broken bolts and use new bolts. If you have a welder you can tack the bolts in place, if not it will still work.
xjfever is offline
post #3 of 3 Old 07-24-2009, 10:05 AM Thread Starter
WoodyinTroy
1993 XJ Cherokee
Thanks! Sometimes I make things harder then they need to be.
I do have a welder so I'll drill out the old bolts from those stupid mounting plates and tack a new bolt in there and attach the nut from inside the fender...that sound right?
I was seriously considering zip ties at 11PM lastnight
fender flare please mavrick XJ Cherokee Technical Forum 10 02-18-2011 09:45 AM
fender flare xjoverkill XJ Cherokee Technical Forum 3 05-02-2008 11:35 AM
Fender flare 97XJnoobie XJ Cherokee Technical Forum 1 10-25-2007 09:59 PM
fender flare for 97+ ??? black98XJ XJ Cherokee Technical Forum 2 02-11-2006 12:43 PM
Fender Flare help?? bamafan378 XJ Cherokee Technical Forum 7 06-16-2005 10:58 PM
