Quantcast need really quick help: oil change and ATF fluid change ?'s - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > need really quick help: oil change and ATF fluid change ?'s
Old 10-12-2003, 03:57 PM   #1
Ryan31783
How many quarts of oil does the 4.0 engine take?
How many quarts of ATF does the tranny take when just changing out the oil in the pan?
I'm putting the Mobil 1 oil filter in and valvoline oil (non-synthetic, I don't know what the previous owner used). For ATF I'm using Coastal dextron III stuff (what I've heard is specified for this tranny). Only reason I'm asking is because the XJ didn't come with an owners manual.
thanks,
Ryan
97 Cherokee Country
03 Kawasaki ZX-636R
Ryan31783 is offline   Reply With Quote
Old 10-12-2003, 04:37 PM   #2
CraigMBA
thanks,
Ryan
The engine takes six quarts.
The tranny needs about three. Go drive it around after you get it refilled and recheck after about 5-10 miles and add accordingly till you get it filled up.
Why spend $11 on a Mobil 1 filter and not use Mobil 1 fluid?
You can, BTW, use Mobil 1 ATF - it's dextron III certified.
1996 XJ Sport - Old Man Emu Springs and Shocks - Banks Stainless Header - BFG Tires - Wilderness Roof Rack - 250,869+ miles, one owner........
CraigMBA is offline   Reply With Quote
Old 10-12-2003, 07:09 PM   #3
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
One of the guys told me that the Jeep auto tranny loses a few ponies with synthetic, too slick. For the motor I swear by it. Switching though the entire drivetrain including the differentials you can gain one or two miles per gallon.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top. Classic4x4 tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
AtoZ Where Zach makes me toys!
Stu-Offroad, because I don't have a clue, but Stu does!
cheesycook is offline   Reply With Quote
Old 10-12-2003, 08:05 PM   #4
ChrisinVA
I will never figure out why people try to put anything other than Dexron III in their transfer cases and transmissions. They were never designed for anything else and work just fine with that.
94 XJ, 4.0/AW4/8.25/242. 145k miles, bought it in march of '02. Rusty's towhook on front, Hidden Hitch out back with shackle. Rebuilt AW4 in January, '03. Kumho MT's on AR767.
ChrisinVA is offline   Reply With Quote
Old 10-12-2003, 09:29 PM   #5
CraigMBA
In short, there is truth in labling on oil, but only to a point.
When I used to sell farm equipment, I got an oppourtunity to attend a Case/IH class on oil. The topic of discussion was why their new oil would go 500 hours under full duty cycle without needing service and the old industry standard would only go 100. The point was that their base oil did not degrade as rapidly as the industry standard, and even though it was more money per quart, you could make up the difference by extending the change interval. Changing oil on a farm tractor in the field using a service truck is a real PITA.
Anyway, after the class, I asked why they didn't just switch to synthetic base oils if they wanted to prolong the base oil breakdown. The engeneer explained to me that in a diesel application, the problem wasn't getting the oil to not break down, but rather the oil became contaminated because diesels ash and contaminate the oil with it as a result of blow by (20:1 or higher compression tends to do that sort of thing). Apparently 500 hours was the limit for getting the oil contaminated enough where you couldn't retain the ash in solution, and the engine would soon start to get ugly and hurt parts.
If it says dextron III, it's dextron III.
I have 236,000 on my tranny and the only thing I've ever done to it is drain-n-fill every 10K with Mobil 1, but if you change the oil often enough, any fluid will be OK. Come to think about it, that's how often I change the engine oil too.
Old 10-13-2003, 01:10 AM   #6
Ryan31783
...so you put ATF in the transfer case? I always thought you should put gear oil in it ???
97 Cherokee Country
03 Kawasaki ZX-636R
Old 10-13-2003, 01:36 AM   #7
CraigMBA
Nope. Takes transmission fluid.
So does the t-5 in my Mustang. Using gear oil in that will destroy the syncros......
Glock Forum
