Need info on correct sway bar end links to purchase? - JeepForum.com
post #1 of 11 Old 11-13-2012, 03:30 PM Thread Starter
ttrevino
I have a '98 XJ with a 4-1/2" lift. The original front sway bar was not on the Jeep when I bought it, but I just installed a salvage one this weekend. So with that, I'm not sure what degree (horizontally) it should be set to, in order to measure the distance from the bar mounting point to the axle mounting point. When I line up the sway bar horizontally level, and measure center to center to the mounting points on the axle, it's 12". Can you please tell me if this is the correct way to measure? And if so, any suggestions for where to buy these extended links? I don't really care if they are quick discos.
Also, I bought a rear sway bar, but my XJ has a Ford Explorer rear end, and the mounting brackets on the factory bar are more narrow than what my axle has on it. Any suggestions on where to get the correct mounts for this, and do I need extended bar end links for this as well? Thanks, Tony
http://www.flickr.com/photos/chopped...in/photostream
ttrevino is offline
post #2 of 11 Old 11-13-2012, 04:41 PM
grainofsalt
For the front I think that it's about 15 degrees up from level.
Depending on how stiff the rear is you may not need a rear sway bar. Do you know what lift kit is on the XJ?
grainofsalt is offline
post #3 of 11 Old 11-13-2012, 05:41 PM
sAe23
1995 XJ Cherokee
The angle doesn't really matter, as long as each side is the same. The reason you want it LOW is so the top of the sway bar doesn't try to bash its way through the inner fender
As for where to buy:
http://www.lmgtfy.com/?q=cherokee+sway+bar+links
sAe23 is offline
post #4 of 11 Old 11-13-2012, 08:08 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The sway bar angle somewhat important, you want 10* up on the front sway bar ends, just like stock.
See the JKS website - http://www.jksmfg.com/support/instal...-2001-2002.pdf
You can leave the rear sway bar in the corner of the garage. You lift kit leaf springs are stiff enough that you won't need it.
CJ7-Tim is offline
post #5 of 11 Old 11-14-2012, 07:31 AM Thread Starter
ttrevino
I'm not sure what type of lift kit is has on it, the PO just said it was a 4-1/2" lift. What I'm trying to fix is when I hit bumps, I'm bouncing all over the place inside the truck. My son calls it Chitty Chitty Bang Bang! I can hit a small bump at just about any speed, and it can bounce me high enough to hit my head on the roof. I'm hoping installing the sway bars will help that?
I don't know if maybe he put on too stiff of leaf springs, or maybe used the wrong shackles?I did notice when looking at some salvage XJs that their leaf springs look thinner and less heavy duty than these. The rear axle is from a '98+/- Explorer, but I looked at those while at the salvage yard too, and their leaf springs don't look this heavy duty either, so maybe that's it?
I'm new to lifted suspensions, so I'm not sure the right direction to go for a better ride.
Thanks for the help, I really need it.
ttrevino is offline
post #6 of 11 Old 11-14-2012, 05:17 PM
grainofsalt
Sounds like worn shock absorbers to me. But You definitely want to put on the front sway bar, Not having it is dangerous.
Just my .02
post #7 of 11 Old 11-14-2012, 06:10 PM
sAe23
1995 XJ Cherokee
It's POSSIBLE the springs are too stiff, but probable that the shocks are worn.
Can you, carefully, stand on the rear bumper and get the rear end to bounce?
As for sway bars, I drove for a month w/o mine hooked up. It's perfectly SAFE, as long as you keep your head out of your rectum
sAe23 is offline
post #8 of 11 Old 11-15-2012, 07:52 AM Thread Starter
ttrevino
I replaced the rear shocks in the last couple of months with some Skyjackers, thinking it was the shocks being bad. That didn't improve it at all. I'm still leaning towards the leaf springs but am not sure.
I've been driving it without sway bars since I bought it in April. So far, my head has remainded where it needs to be....
However, I am concerned if I hit too large a bump, or something out of my control happens, and causes a wreck. That's the main reason I'm trying to figure this out.
ttrevino is offline
post #9 of 11 Old 11-15-2012, 11:31 AM
sAe23
1995 XJ Cherokee
I just tried to get my rear springs to "bounce" by jumping on my hitch, and it was rather stiff. I don't think I got more than an inch or two of movement.
This might not be a good way to test the stiffness of your springs.
And, yeah, in an emergency situation you might get into trouble if you had to do some hard maneuvering w/o the front swaybar.
I just drove carefully, and avoided speeding down canyon roads
sAe23 is offline
post #10 of 11 Old 11-15-2012, 12:58 PM Thread Starter
ttrevino
I emailed the PO, and he said the rear springs are "4 inch lift springs", which are stiffer than stock. sAe23, that's how I usually test for shock wear, but even with the older shocks I replaced this year, there wasn't excessive bounce when sitting still. It's only when I'm driving, hitting bumps in the road that it'll bounce hard. It's gotta be from the heavier springs. I might just have to add some extra rear end weight, (thinking of a heavy-duty bumper with spare tire carrier!), maybe that'll help.
ttrevino is offline
post #11 of 11 Old 11-16-2012, 01:09 AM
sAe23
1995 XJ Cherokee
Yeah, several 50LBS bags of cement/fertilizer/dog food would be a good test
sAe23 is offline
suspension
