Need Immediate Technical Advice - Low Oil - JeepForum.com
post #1 of 6 Old 12-17-2006, 02:35 PM Thread Starter
dwilliamsceg
Hey guys and gals,
I potentially have a great deal on a 2000 XJ but it has one technical issue that has me contemplating the buy.
After about 10 minutes, the oil pressure gauge drops to zero. The seller has replaced the oil pump and the oil pressure sensor switch. The Jeep runs great with no knocking, pinging (other than valve tick), and is in generally great conditions. So, my questions are:
1. Is this a common error for this year? If so, what is the fix?
2. Is there a pressure sensor probe (like for cooland temp) that senses the oil pressure? If so, could this have gone bad?
3. Could the gauge itself be bad?
The seller is willing to let me take it home for a day or so to test drive it for the weekend. If the Jeep is truly getting zero oil pressure, would it not seize after a few minutes of running?
Any advice is much appreciated!!!
Dave.
dwilliamsceg is offline
post #2 of 6 Old 12-17-2006, 03:20 PM
AZ Jeff
2014 JK Wrangler
If the seller has done what he claims, and the hot idle oil pressure is showing "0", then it's time to temporarily install a mechanical guage on the engine, and get a reading on the REAL oil pressure.
If it's as low as the electric guage says it is, then the problem is probably loose bearing clearances, and, at a minimum, a new bearing set will be needed.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 6 Old 12-17-2006, 03:25 PM Thread Starter
dwilliamsceg
Thanks Jeff.
1. Where can I buy/use a mechanical oil pressure gauge?
2. Where do I hook up the gauge?
Thanks! Dave.
post #4 of 6 Old 12-17-2006, 03:26 PM
creature
creature's Avatar
The jeep wouldn't likely sieze after a few minutes with zero oil pressure, I have heard stories of these engines going as far as 200 miles with no oil
-Shawn
creature is offline
post #5 of 6 Old 12-17-2006, 04:50 PM
Jeff in PA
Jeff in PA's Avatar
Originally Posted by dwilliamsceg
Thanks Jeff.
Thanks! Dave.
You'll be able to get a mechanical oil pressure guage at your local auto parts store. Auto Zone, NAPA, Pep Boys, Western Auto etc.
Jeff
Jeff in PA is offline
post #6 of 6 Old 12-17-2006, 06:04 PM
AZ Jeff
2014 JK Wrangler
Jeff
And you hook it up by threading the end of the tubing into the same hole where the electric pressure sender would screw in.
AZ-Jeff
AZ Jeff is offline
Many technical questions about 89 Limited BreadnButter XJ Cherokee Technical Forum 18 08-20-2009 11:10 AM
Technical Lift Question onlyinajeep07 XJ Cherokee Technical Forum 3 04-15-2007 11:11 AM
I need some technical advice, anyone up for it? whitestallion XJ Cherokee Technical Forum 12 10-12-2006 02:26 PM
Technical Manual rexlam XJ Cherokee Technical Forum 2 08-25-2006 12:00 PM
Not so technical question bluesman905 XJ Cherokee Technical Forum 10 03-18-2006 09:03 AM
