-   -   Need Immediate Technical Advice - Low Oil (http://www.jeepforum.com/forum/f11/need-immediate-technical-advice-low-oil-351439/)
dwilliamsceg 12-17-2006 02:35 PM
Hey guys and gals,
I potentially have a great deal on a 2000 XJ but it has one technical issue that has me contemplating the buy.
After about 10 minutes, the oil pressure gauge drops to zero. The seller has replaced the oil pump and the oil pressure sensor switch. The Jeep runs great with no knocking, pinging (other than valve tick), and is in generally great conditions. So, my questions are:
1. Is this a common error for this year? If so, what is the fix?
2. Is there a pressure sensor probe (like for cooland temp) that senses the oil pressure? If so, could this have gone bad?
3. Could the gauge itself be bad?
The seller is willing to let me take it home for a day or so to test drive it for the weekend. If the Jeep is truly getting zero oil pressure, would it not seize after a few minutes of running?
Any advice is much appreciated!!!
Dave.
AZ Jeff 12-17-2006 03:20 PM
If the seller has done what he claims, and the hot idle oil pressure is showing "0", then it's time to temporarily install a mechanical guage on the engine, and get a reading on the REAL oil pressure.
If it's as low as the electric guage says it is, then the problem is probably loose bearing clearances, and, at a minimum, a new bearing set will be needed.
dwilliamsceg 12-17-2006 03:25 PM
Thanks Jeff.
1. Where can I buy/use a mechanical oil pressure gauge?
2. Where do I hook up the gauge?
Thanks! Dave.
creature 12-17-2006 03:26 PM
The jeep wouldn't likely sieze after a few minutes with zero oil pressure, I have heard stories of these engines going as far as 200 miles with no oil :eek:
Jeff in PA 12-17-2006 04:50 PM
Originally Posted by dwilliamsceg
Thanks Jeff.
Thanks! Dave.
You'll be able to get a mechanical oil pressure guage at your local auto parts store. Auto Zone, NAPA, Pep Boys, Western Auto etc.
:wave: Jeff
AZ Jeff 12-17-2006 06:04 PM
:wave: Jeff
And you hook it up by threading the end of the tubing into the same hole where the electric pressure sender would screw in.
The time now is 11:44 PM.
