Need Help with turn signals not working - JeepForum.com
post #1 of 3 Old 05-01-2012, 03:56 PM Thread Starter
JeepGuy1993
1995 XJ Cherokee
The turn signals on my jeep stopped working. The wipers, the emergency lights, and the bright lights work but not the turn signals themselves. Any ideas on how to fix this problem would be great. I have checked all the fuses and replaced the relay at the bottom of the fuse box. Any ideas would be great.
JeepGuy1993 is offline
post #2 of 3 Old 05-01-2012, 04:10 PM
GunHo198
By relays do you mean the Flasher relay under the dash? Not sure about the XJ, but my YJ has 2. One for turn signals, and one for the hazards...
94 Jeep Wrangler 4.0 with AX-15 Trans.
4" Procomp Lift, 3" body lift, 35" BFG Tires, Ford 9" Rearend with NASCAR Detroit Locker, Super 30 Front with ARB, Onboard Air, Dual Optima Batteries,Warn M8274 Winch, and Bushwacker Fender Flares.
GunHo198 is offline
post #3 of 3 Old 10-13-2012, 09:08 PM
duckhunter17
Yeah mine has the same problem but I just have 1 relay under the dash ???
duckhunter17 is offline
electrical
Turn signals not working... Yojimbo XJ Cherokee Technical Forum 2 09-09-2011 11:32 AM
Gauges and turn signals not working. Showtime3492 XJ Cherokee Technical Forum 0 06-13-2010 03:35 PM
Turn signals not working............ g26 XJ Cherokee Technical Forum 1 05-26-2009 09:37 PM
turn signals not working cardana24 XJ Cherokee Technical Forum 4 10-09-2006 10:56 AM
99 turn signals not working 46CJ2A XJ Cherokee Technical Forum 4 01-10-2005 02:36 PM
