Need help quick please! - JeepForum.com
post #1 of 5 Old 08-23-2014, 02:23 PM Thread Starter
ZackTheJeeper
I have a 2001 Cherokee XJ, The airbag light came on and the horn stopped working all of the sudden at the same time. When I lock it with the remote the horn beeps but nothing happens when I push the horn. I changed the relay but did not solve the problem. Any suggestions so I can get this thing inspected???????
ZackTheJeeper is offline
post #2 of 5 Old 08-23-2014, 03:10 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Sounds like you might have a bad clockspring. If you're fairly handy it is possible to repair or replace it yourself. If you choose to check it out, you'll want to make sure you disconnect the battery cables first so that the airbag doesn't blow up in your face. XJ Clock Spring Repair Write-up
***Chris***
chris87xj is offline
post #3 of 5 Old 08-23-2014, 03:57 PM Thread Starter
ZackTheJeeper
Originally Posted by chris87xj View Post
Sounds like you might have a bad clockspring. If you're fairly handy it is possible to repair or replace it yourself. If you choose to check it out, you'll want to make sure you disconnect the battery cables first so that the airbad doesn't blow up in your face. XJ Clock Spring Repair Write-up
Thanks man I'll check it I'll let you know if it worked
post #4 of 5 Old 08-26-2014, 09:44 PM Thread Starter
ZackTheJeeper
THANK YOU SO MUCH! A few hours after this post my check engine light also came on but after I changed my clock spring which was fairly easy my airbag and check engine light went off and my horn worked.
post #5 of 5 Old 08-27-2014, 04:18 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
***Chris***
