Need Help please read. - JeepForum.com
post #1 of 9 Old 09-08-2007, 12:23 AM Thread Starter
Abstrastic
1997 XJ Cherokee
1988 Cherokee 4.0 inline 6 automatic 4x4. Didn't run when I bought it had been sitting in a barn for a yr and a half. Also wasn't getting fuel when i bought it. Has 250K miles on it. Motor was rebuilt at 200K miles.
All Fuses are okay.
It is getting fuel but no spark. What has been replaced in the past three days:
Battery (replaced cuz there wasn't one)
Battery Cables (Destroyed)
Spark Plugs (Way past Shot)
Spark Plug wires (weren't any on the jeep)
Ignition Coil (Bad)
Relay/ Ballast Resonator (Bad)
Crankshaft Position Sensor (Just Because it is known to cause problems)
Being replaced tomorrow if bad:
Rotor
I am out of ideas.
Please Help.
Thanks,
Evan.
Abstrastic is offline
post #2 of 9 Old 09-08-2007, 07:22 AM
lbsnowryder
One notch above Redneck!!
lbsnowryder's Avatar
Double check ground on block and make sure you are getting spark at the coil. Swap the relays around under the engine compartment also. Start there and return here with results.
LB
_____________________________________
I own a Jeep, it's red and has big tires
lbsnowryder is offline
post #3 of 9 Old 09-08-2007, 12:16 PM Thread Starter
Abstrastic
1997 XJ Cherokee
Dumb question: do you mean spark from the distributor to the coil or vise versus?
post #4 of 9 Old 09-08-2007, 12:19 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
If your replacing the rotor, get the cap as well. Do you know if your getting spark to the cap????
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 9 Old 09-08-2007, 12:21 PM
rustywrangler
He prolly means spark from the coil to the distributor. The grounds thing can be a cause for no spark as well. The negative batt connection to the block and the ground from firewall to block.
post #6 of 9 Old 09-08-2007, 11:06 PM Thread Starter
Abstrastic
1997 XJ Cherokee
I cleaned the negative connection at the block as well as the ground from the firewall to the block.
I am not getting spark to the cap.
post #7 of 9 Old 09-09-2007, 12:32 AM
rustywrangler
What is the condition of your coil????
post #8 of 9 Old 09-09-2007, 03:19 PM Thread Starter
Abstrastic
1997 XJ Cherokee
Brand new.
Update. That relay that I replaced, well when the old one was on the fuel pump wouldn't run But I did get spark. Now with the new relay installed The fuel pump runs but no spark. I put the old relay back on and sprayed starter fluid in the intake and it started right up. I am thinking maybe I got a bad relay.
Edit: I got it to start with the new relay but only after I used starter fluid in the intake. And it doesn't work every time. It is like the spark is intermentted.
post #9 of 9 Old 09-14-2007, 08:31 PM Thread Starter
Abstrastic
1997 XJ Cherokee
Update since the relay. Fuel Pressure Regulator started leaking a few nights ago so i replaced it. The fuel pressure seems to have gotten a bit better after changing that out. But still not running. So... I took out the injectors and let them soak in a bucket of B-12 for 24hrs. I let them dry for about 12hrs. I just got done putting them back in and hooking everything back up. Cleaning the injectors did seem to help a bit. It is actually trying to start now, but wont.
Any ideas?
new to mj please read muddy_jeep_love MJ Comanche Technical Forum 4 09-05-2009 10:52 PM
ya i read the sye but i got a ? still murrayman23 XJ Cherokee Technical Forum 4 11-09-2007 05:58 AM
Anyone read this yet????? deragheth XJ Cherokee Technical Forum 0 04-11-2006 11:22 PM
Hey, READ and please help... damnurlies XJ Cherokee Technical Forum 8 09-02-2005 08:43 PM
please read krs96XJ XJ Cherokee Technical Forum 2 09-20-2003 10:24 AM
