NEED HELP PLEASE P1391 Trouble Code - JeepForum.com
post #1 of 5 Old 03-25-2012, 04:24 PM Thread Starter
Sandfreak8
Hello I have 1998 Jeep Cherokee Sport 4.7L Stroker That I keep getting a P1391 Trouble code. I have replaced the Crank Position Sensor, Re Indexed the Distributor same results. The Engine starts up and runs fine just keeps setting this code and preventing me from getting an emissions test. Any Help will be greatly appreciated.
Sandfreak8 is offline
post #2 of 5 Old 03-25-2012, 04:43 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
P1391 is intermittent loss of the "crankshaft position sensor" signal OR the "camshaft position sensor" signal.
Any symptoms??
As you have replaced the crank sensor and it hasn't resolved, time for a new cam sensor.
Good luck and keep us updated!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 5 Old 03-26-2012, 07:59 AM Thread Starter
Sandfreak8
I have replaced the distributor i guess it is possible that the cam Position Sensor in the distributor is defective. The Jeep has no symptoms it starts and runs fine, that is why I am at such a loss.
post #4 of 5 Old 03-26-2012, 09:40 AM
tjwalker
tjwalker's Avatar
First, I would clear the codes and at the same time, I'd clean the connector for the cam sensor with a thorough spray of electrical contact cleaner and then add a dab of dielectric grease to the connector and reconnect.
If the same code returns after that, I'd replace the cam sensor, even if you have no symptoms. There still could be an issue that isn't bad enough for you to sense.
tjwalker is offline
post #5 of 5 Old 03-26-2012, 09:41 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
P1391 (M)Intermittent Loss of CMP or CKP. Loss of the Cam Position Sensor or Crank Position sensor has occurred.
Several recent threads have been posted by Cherokee owners that have had issues with random CMP and CKP/CPS codes and some starting or running issues. In these threads a new generic CPS from Advance/IdiotZone/O'Reilly's did not resolve the issues.
What made the difference, was installation of a genuine Jeep CPS from the dealership. Cheap sensors can be not quite the correct size or can be slightly out of specification, enough so that the engine doesn't run right, despite the new parts called for by diagnostic testing.
Cheap parts are cheap for a reason.
CJ7-Tim is offline
98 xj throwing p1391 code llurz1 XJ Cherokee Technical Forum 2 03-12-2012 03:10 PM
code p1391 p0138 p0783 p0340 troy225 XJ Cherokee Technical Forum 1 07-03-2010 09:17 PM
failed inspection - code P1391 - check engine light not functioning JV96XJ XJ Cherokee Technical Forum 6 03-20-2010 08:25 AM
P1391 Code madfire XJ Cherokee Technical Forum 2 12-21-2009 03:55 PM
after powertrain swap getting code P1391 cam sensor HELP! 93ZJbeast XJ Cherokee Technical Forum 6 05-18-2009 11:11 AM
