need help.. no turn signals in my 88 Pioneer - JeepForum.com
post #1 of 5 Old 06-17-2013, 08:03 AM Thread Starter
scoutmomof3innc
1988 XJ Cherokee
My 88 runs great.. except that I have no turn signals.. the hazards work fine... have changed all the bulbs, all the fuses, the flashers, the switch and the circuit breaker... still no turn signals... where is the ground wire for these its the only thing I haven't checked and changed... am considering changing the whole turn signal assembly if needed... would love input and guidance
scoutmomof3innc is offline
post #2 of 5 Old 06-17-2013, 09:29 AM
CSP
This really should be posted in the XJ Cherokee forum.
CSP is offline
post #3 of 5 Old 06-17-2013, 09:39 AM
JoshuaGoodwin88
Use a steering wheel puller and make sure everything is good in the steering column
JoshuaGoodwin88 is offline
post #4 of 5 Old 06-17-2013, 10:19 AM
pleontks
1976 J-Series Truck
did you change both flasher relays? One for blinkers, one for hazards.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #5 of 5 Old 06-17-2013, 04:59 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I suggest unplugging EVERY electrical connection in the engine bay you can find, whether engine related or not, and spraying it out with a good electronics cleaner, visually inspecting the terminals making sure they haven’t retracted into the plastic holder, and then plugging it back together. There’s a critical 10-pin connector for the front lighting system located in front of the air cleaner and behind the left headlight assembly. Don’t miss that one. Also be sure that the connectors to the ballast resistor mounted near the air cleaner housing are clean and tight.
ALL of the relays should be removed, the terminals wire-brushed until shiny, and the receptacles sprayed out with contact cleaner. Then plug them back in. I do this on every Renix Jeep I purchase or work on for someone else.
Revised 07/23/2012
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
