Need Help with my yoke!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Need Help with my yoke!!!
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-28-2011, 05:56 PM   #1
BlueOnBlack
1993 XJ Cherokee
my yoke is only 2 inches in the t case and is causeing vibrations. it will not even pull up on a curb with out trying to grind the splines. i am afraid it my wear the end of the yoke out.? anyone one a good cheap slipyoke site or a go extended yoke site? i herd i could drop the transfer case but im on a limited income. is there a cheap easy way to fix this problem???
93 cherokee with 4'' lift.
dana 35 in rear i beleive its mostly stock. just recently lifted.
message for more info
BlueOnBlack is offline   Reply With Quote Quick reply to this message
Unread 02-28-2011, 06:03 PM   #2
xjfever
xjfever's Avatar
1995 XJ Cherokee
It would help if you gave some more info, like year model lift amount, transmission and t-case as well as rear axle.
xjfever is offline   Reply With Quote Quick reply to this message
Unread 02-28-2011, 06:23 PM   #3
Topgun514
1988 XJ Cherokee
You could get a manual trans. driveshaft. I assume you have an AW4 tranny but I would look for a SYE to be honest with those results. Doesnt sound like you should drive it like that too much.
Two inches in is not an impressive amount either, You want as much in there as you can without bottoming out.
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline   Reply With Quote Quick reply to this message
help needed , slip yoke eliminator , transfer case drop , yoke
