Need help with lift setup - JeepForum.com
post #1 of 11 Old 06-10-2013, 09:33 PM Thread Starter
MrSundays
So Im trying to figure out what to do with my lift. On one hand I really would like to get the OME 1.5" lift kit because it comes with shocks and transfer case drop hardware. However, its $810. I pieced together a 2" setup with OME leafs, skyjacked coils, U-bolts, and brake lines for about $550. However, it wont come with shocks. Im looking for a 2.5" overall lift so if I go the route of the 1.5" OME I will be adding spacers and shackles if needed.
My questions are:
If I do 2.5" lift, the brake lines and possibly the TC drop but what else is potentially required? I dont need to adjust the pitman do I?
Is it recommended to get new control arms?
What would be the best route to do the lift? I understand shackles and spacers do exactly do great things for the ride and longevity of the suspension.
This is the first lift Im actually going to do myself and its so mild that its tough to find a kit or information that has everything I need. Thanks!
SOLD- '13 JKR with lots of goodies
Current- '98 TJ Sahara: build coming in October
MrSundays is offline
post #2 of 11 Old 06-11-2013, 12:10 AM
chance_p
2008 WK
Brake lines will be fine at 2.5. Probably wont need a tc drop either. No need to do anything involving the pitman arm. Im a big advocate of getting an adjustable tracbar at any height over stock. At 2.5 keep the stock control arms. At 3+ is when you should get longer ones. Spacers have no negative effect on coil springs. Shackles wont hurt an aftermarket leaf pack. Id recommend shackle relocation brackets over shackles though. They will give you 1 inch of lift and greatly improve ride quality.
08 WK 4.7 QTII - 4" Superlift - JK Moabs - 265/70 Cooper AT/3 - Flashpaq
chance_p is offline
post #3 of 11 Old 06-11-2013, 12:57 AM
Dwatts5250
1997 XJ Cherokee
one of the vendors.. Rockridge4wd has 3"lift kits, springs, shocks and ubolts smidge over $500 zone offroad kit
i talked with derran.
http://www.jeepforum.com/forum/f43/r...level-1369589/
thats the link...hopefully, or just go to the vendors section, bout half way down.
"A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America' for an amount of up to and including my life. That is Honor, and there are way too many people in this country who no longer understand it."
Dwatts5250 is offline
post #4 of 11 Old 06-11-2013, 10:27 AM Thread Starter
MrSundays
Oh yes, thats what I originally planned on. You get so many things going through your head that you forget things youve had in mind all along
I know a few people who have Zone kits and they dont like them. Im going to spend a little extra for good quality as I will probably be selling the XJ in a year to get a TJ/JK. The XJ isnt even for sale yet but Ive had offers for more than I bought it for. I want to have it have a factory upgraded appearance.
post #5 of 11 Old 06-11-2013, 11:34 AM Thread Starter
MrSundays
Right now Im looking at doing the OME 1.5" kit with shackle relocation brackets. Looks like the best option for me.
post #6 of 11 Old 06-11-2013, 02:08 PM
chance_p
2008 WK
Sounds likea solid plan. Post a link to that kit. Im curious as to whats included in it. There are cheaper options but i think youll have the best ride quality with that setup.
chance_p is offline
post #7 of 11 Old 06-11-2013, 06:08 PM
foggybottombob
Shackle relo brackets are absolutely necessary if you want to change the length of XJ shackles. I have 3" lift springs on my XJ but they give me 4.5" of lift. I had 4.5" springs at one time and that gave 6" of lift. So unless you have heavy accessories like a winch you will likely get more lift than what is advertised for a set of parts.
foggybottombob is offline
post #8 of 11 Old 06-11-2013, 07:12 PM Thread Starter
MrSundays
Here is the link:
http://www.quadratec.com/products/76090_80X_PG.htm
It's going to yield the best ride quality and the OME springs are the best out there.
Sent from my pocket brick
post #9 of 11 Old 06-11-2013, 07:17 PM Thread Starter
MrSundays
I've talked to people who have the MD springs that sit about .5" higher than advertised. The relocation brackets yield 1"
post #10 of 11 Old 06-11-2013, 08:30 PM
foggybottombob
With relo brackets you get the option of playing with shackle lengths if you need to. You can make any reasonable length shackle work.
post #11 of 11 Old 06-11-2013, 08:34 PM Thread Starter
MrSundays
Right, I was saying with the stock shackles it will add 1" from what I understand.
