Need help installing a new distibutor - JeepForum.com
post #1 of 3 Old 07-02-2013, 05:31 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
I've read a few write ups and they all say mark where the distributor was before taking it out. Problem is, this is a rebuilt block so there obviously I can't mark anything. Tips?
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #2 of 3 Old 07-02-2013, 07:34 PM
Saudade
1988 XJ Cherokee
The procedure is called "indexing". Basically, you set the engine to TDC, compression stroke on #1 cyl, then drop in the dist so the rotor points at the #1 wire on the cap.
Not sure if there are different details given yours is an HO with a Renix block.
http://mikestrawbridge.com/blog/2011...utor-indexing/
Saudade is offline
post #3 of 3 Old 07-02-2013, 07:39 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
If you drink, I owe you a beer.
