Quantcast Need Help Finding High-Beam Wire On '00 XJ. - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Need Help Finding High-Beam Wire On '00 XJ.
GR8TOPS Introduces the Exogate HD Tire CarrierIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Old 05-25-2009, 01:23 PM   #1
allibaster
2010 JK Wrangler
Trying to install my new lights. Instructions on my Hellas are telling me to splice into the high beam wire.
What is the simplest way/method of finding this wire? I don't have an electrical testing device. I only have a multimeter handy.
allibaster is offline   Reply With Quote
Old 05-25-2009, 01:47 PM   #2
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Originally Posted by allibaster View Post
..What is the simplest way/method of finding this wire?..........
a multimeter
Set the meter to voltage and probe the headlamp socket with the red lead in the socket and the black lead grounded, as your helper flips the high beams on and off.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 05-25-2009, 01:51 PM   #3
allibaster
2010 JK Wrangler
Maybe someone has personal experience with a known exposed location and wire color?
I've already stripped out a seized up screw trying to remove the headlamp.
Old 05-25-2009, 08:23 PM   #4
allibaster
2010 JK Wrangler
Got it.
Front Left Light
Violet - Low Beam
Black/White Stripe - High Beam
Red - Ground
Wired up and working good with my high-beams.
Glock Forum
