Need help changing spark plugs - can't get coil rail out - JeepForum.com
post #1 of 17 Old 10-25-2008, 07:00 AM Thread Starter
ajcannon
It's my first time changing spark plugs - and I need some help almost before I've even started. I've removed the four bolts from the coil rail, but I am not sure how to get it out. I can wiggle it and it will come loose, but my problem is that some of the hoses get in the way. My real question is do I need to disconnect these hoses, or should I just work around them?
I said it's my first time changing spark plugs - it's really my first time doing almost anything, so I figured it was better to ask first before I just dive in and guess. I read a write-up somewhere on how to change the spark plugs, but I think whoever wrote it had a different model than I've got so I wanted to ask here.
I'm driving a 2000 Jeep Cherokee Sport with a 4.0 I6.
ajcannon is offline
post #2 of 17 Old 10-25-2008, 07:24 AM
xjpro
In order to do it you will need to disconnect the heater hoses in your way in order to take the coil pack out, and after you do so find your way and move them in every possible way to free them. If im not wrong they rub a little on the A/C compressor before finally going out.-
HTH
xjpro
01 xj limited
ZJ rear disc brakes with working parking brake
Electric fan conversion with spal fan controller
xjpro is offline
post #3 of 17 Old 10-25-2008, 07:28 AM
OLDoRedoWolf
I had the same problem with my 2001. You just gotta work it off & maneuver it out of the way. It's pretty annoying, but you can do it.
I think you can disconnect the power cable from the rail on the far end, that would make it easier, & then you could just take it out.
OLDoRedoWolf is offline
post #4 of 17 Old 10-25-2008, 08:12 AM
MXdude105
i didn't disconnect any of that stuff. just wiggle the coil packs around a bit and they will come out with some effort.
-2013 JK Wrangler Sport 4x4. True Blue, 6spd.
-2000 XJ Cherokee Sport 4x4. 4.0L, NP231, c8.25, aw4, RC 3" AAL........SOLD
-1995 Mustang GT 302
MXdude105 is offline
post #5 of 17 Old 10-25-2008, 08:30 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by MXdude105 View Post
i didn't disconnect any of that stuff. just wiggle the coil packs around a bit .
Me too. I didn't have to disconnect or remove anything. Gently tug or push the coil rail aside until you have enough room to get at the spark plugs. I think I used an extension with a wobble end to get better access to the spark plugs.
CJ7-Tim is offline
post #6 of 17 Old 10-25-2008, 08:39 AM
waltercrovo
yep, no need to remove anything extra, you can gently get everything clear.
waltercrovo is offline
post #7 of 17 Old 10-25-2008, 08:42 AM Thread Starter
ajcannon
Thanks everyone - still trying to figure this out, but I'll give it another shot in a little bit after the engine cools down.
I basically gave up earlier, after I couldn't get the hoses disconnected (I didn't want to cut them off and replace them and they would not come loose at all.) I connected everything back up (with the old plugs still) and drove it around for a few miles to make sure that it was running OK. Actually - while I'm at it, let me as everyone a question. I connected everything back up and started the jeep. It turned over and then almost immediately shut off. I gave it a few seconds and started it again - drove it around and everything seems to be working as normal.
Think that the starting issue was just a coincidence, or do you think I've missed a connection somewhere. It's started three times since then without problems and I've driven it and it seems to be driving normally.
Anyways, back to the original issue - I'm going to wait for the engine to cool down a little more and then I'll go back out and give it one more shot. After that I'll take it in to get it done. I'm just scared that in the process of me trying to save a little money I'll end up breaking something that will cost a heck of a lot more to fix than I've saved.
Thanks again everyone for your help - I really appreciate it. Have a great weekend.
-Andrew
ajcannon is offline
post #8 of 17 Old 10-25-2008, 11:06 AM
sundevilkid
sundevilkid's Avatar
Distributor less Jeeps are so weird
I just did mine yesterday... Just had to move the wiring harnesses around at the back of the block, but all others were a sinch, only took about 20 minutes to get the old ones out and new ones back in again.
1996 XJ Classic
My sig got too long. So we'll just say it's Friggin' Sick.
sundevilkid is offline
post #9 of 17 Old 10-25-2008, 12:36 PM
footypaul
Whey in the heck dont they make things you are going to HAVE to replace easier to remove.
Engineers need to spend some time with mechanics before they are allowed to design a vehicle.
footypaul is offline
post #10 of 17 Old 10-25-2008, 02:03 PM Thread Starter
ajcannon
Thanks for everyone's help. I ended up taking it up to a friends shop to get it done - he charged me a fair price and I felt better knowing that someone who knew what they were doing did it. I just threw my bike in the back of the Cherokee and drove up there, rode back to my house, watched some football, and went back to pick it up later. I'll try it the next time they need them (but it will be a while - I don't drive very much).
Thanks again to everyone who answered me on this thread, and my other thread regarding which plugs to use. Y'all have a great weekend and enjoy some football now.
-Andrew
EDIT: Oh and by the way, it does run much smoother now - I'm glad that it's been done.
ajcannon is offline
post #11 of 17 Old 10-25-2008, 02:10 PM
EagleStorm
2008 WK
bend the hose's out of the way no need to disconnect anything. you just need to gain access to the plugs you dont need to lay the coil rail on the bench just move it out of the way
EagleStorm is offline
post #12 of 17 Old 04-15-2009, 05:15 PM
LazersGoPEWPEW
I'm about to do this change to mine and is it really necessary to remove the hoses? It's not a huge deal as I imagine I can get them off but I don't like doing more than I have to. Anyone have the torques required for the plugs and the coil packs?
LazersGoPEWPEW is offline
post #13 of 17 Old 04-16-2009, 08:18 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by LazersGoPEWPEW View Post
... the torques required for the plugs and the coil packs?
Spark Plugs - 25 ft/lbs
Coil Rail 250 - INCH/pounds (barely tight)
CJ7-Tim is offline
post #14 of 17 Old 04-16-2009, 09:31 AM
xjarchaeologist
This. I just tugged, got it off, and shoved it down and out of the way. The plugs are easy to get to, expect for the last one by the firewall.
It's an easy task unless the last ******* to put your plugs in overtightened them and the ceramic breaks as you loosen it...
2001 Cherokee
31x10.50 Dunlop Mud Rovers, OME HD Leafs, RE Coil Spacers
xjarchaeologist is offline
post #15 of 17 Old 04-16-2009, 10:07 AM
suprdave80
sounds like the same guy that worked on yours worked on mine
never ceases to amaze me how many stupid things i find out he did as i work on my engine. good thing the engine as a whole is solid, just everything around or on it was done stupidly
As for replacing spark plugs -
unbolt coil rail, pull off, shove out of the way. no need to disconnect anything.
it helps to have a jointed socket extension to get to a couple plugs, particularly number six, which is sorta behind the tranny fill tube.
suprdave80 is offline
Changing Spark Plugs?????? rdorazil33 XJ/MJ Cherokee Non-Technical Forum 4 10-28-2009 11:47 PM
When changing spark plugs... Jerka XJ Cherokee Technical Forum 7 07-19-2006 01:07 PM
Changing spark plugs EJames1226 XJ Cherokee Technical Forum 9 05-27-2006 12:21 PM
changing the spark plugs on an '01??? ChiTown'01XJ XJ Cherokee Technical Forum 12 05-26-2005 11:40 PM
Changing spark plugs NIN_Jeep XJ Cherokee Technical Forum 9 08-07-2002 05:49 AM
