Need Help 1996 Cherokee Sport - JeepForum.com
post #1 of 8 Old 02-11-2007, 08:44 AM Thread Starter
nmblkmtn1
Greetings all I'm new to this site and new to Jeeps. I have a 1996 Cherokee
Sport, I'm having starting problems. When I turn the key at times I get nothing. All the lights work and radio. The Starter was just replaced, which was not the problem, sometimes it will start in neutral. I had the same problem with my 67 ford, and it was the starter realy, don't know if jeeps have such a part. All feedback would be helpful.
thanks
J
nmblkmtn1 is offline
post #2 of 8 Old 02-11-2007, 08:45 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
I am thinking your Neutral Safety Switch. Search that and youll find a good write up or two on there. You could repace it for a couple hundred bucks, but cleaning it would be easier and cheaper. So do a search and see if that sounds like your problem.
88XJSport is offline
post #3 of 8 Old 02-11-2007, 08:48 AM
bee guz
I looked for a new one for a guy here yesterday, and autozone wanted 238.00 so you better check it out good, it may just need adjustment, or cleaning.
bee guz is offline
post #4 of 8 Old 02-11-2007, 09:03 AM Thread Starter
nmblkmtn1
thanks or the feedback I will check it out and let you know what happens.
post #5 of 8 Old 02-11-2007, 10:46 AM
T4STE
same thing happened to me this weekend. everything you just said, except it was the starter that was donzo with mine. i got it replaced part and labor for $200 not bad. bee guz looked for the price for neutral safety switch for me (thanks) but it wasnt that. good luck though
16 WK2 75th Anniversary-Lucille the Albino Rhino
96 XJ Sport-Rosemary the Perrywinkle People Eater
T4STE is offline
post #6 of 8 Old 02-11-2007, 03:52 PM
jeephack
I had the same problem with my neutral safety switch once. A couple of wires from the starter solenoid to a spring loaded toggle switch mounted through the dash under the steering wheel, and now it starts whenever I tell it to! Doesn't care what position the shift lever is in.
jeephack is offline
post #7 of 8 Old 02-11-2007, 04:09 PM
bee guz
Thats a hell of a lot better than that 240 dollar switch...
bee guz is offline
post #8 of 8 Old 02-11-2007, 06:04 PM
Rescue XJ
I had the same problem. It was the terminals on my battery cables.
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
1996 Jeep Cherokee Sport GravyTrain7 XJ Cherokee Technical Forum 11 03-13-2017 06:11 PM
How To Replace Spark Plugs On 1996 Cherokee Sport? wick001 XJ Cherokee Technical Forum 15 11-12-2013 08:12 PM
1996 Cherokee Sport Possible brake noise mkeiler XJ Cherokee Technical Forum 17 11-10-2011 12:33 PM
Starter - 1996 Cherokee Sport rdm7938 XJ Cherokee Technical Forum 27 02-11-2010 05:29 AM
1996 Jeep Cherokee Sport recommend exhaust jeffsjeep XJ Cherokee Technical Forum 4 06-19-2002 09:28 PM
