Need help with 1990 XJ Wagoneer Limited Driver Power Window! - JeepForum.com
post #1 of 5 Old 09-22-2013, 08:44 PM Thread Starter
DaSupercharger
1990 XJ Cherokee
Hi everyone!
So I've been lurking around the forum ever since I bought my Waggy back last October and this forum has been INVALUABLE as hell to me to the point where I've never had to post any questions about my Renix problems before because someone had already figured it out
This time though I'm a bit stumped and need your help. So my driver side window rolls down half way and can only go up 6" and never closes. It never makes any noises at the top extreme or bottom but it does seem like the motor is working but can't push/pull any further?! It just started doing this and thats bad here out in the cold here in Pennsyltucky
Now I'm good with mechanical things like engines etc etc but the whole window mechanism doesnt look very familiar to anything I've found so far because all the stuff I have found on the forum has been for either mid to late 90's XJ's or just ZJ's and WJ's. I think its my window regulator thing but have NO IDEA where the hell it is or what it looks like. Isn't a Window Regulator and a Window Motor the SAME THING??
Any help would be appreciated! Here's a pic of how far I got:
And the last 2 pics are of my ghetto solution
PS: I also was wondering what Paint Code I have?! It would be nice to figure that out! I've searched high and low on the interwebs but haven't been able to figure it out as of yet.
DaSupercharger is offline
post #2 of 5 Old 09-23-2013, 11:58 AM
79chiefs
1988 XJ Cherokee
Pull the regulator off and check if it is binding, my 92 did that when trying to go up.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #3 of 5 Old 09-23-2013, 12:24 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Sometimes the rubber window channel inside the door gets bunched up. Sometimes the metal frame inside the door that holds the window channel moves enough to allow the window to get crooked and bind up. Sometimes the window regulator mechanism or the window motor fails.
CJ7-Tim is offline
post #4 of 5 Old 09-23-2013, 01:36 PM Thread Starter
DaSupercharger
1990 XJ Cherokee
Okay, so we have some good starting points for me to look at! Prior to the failure, it was acting a bit funny where it wouldn't go down completely into the door and would make a grinding sound if you tried to take it past that point BUT it went all the way up just fine! Furthermore, the window does seem to be a bit loose as you can grab it and move it around an 1/8" left or right. Also, is the window regulator the thing attached to the shiny bracket in my 1st picture in the middle of the door or is that the window motor? I won't have much time over the weekend so just want to try to do it in as less time as possible
THANK YOU!
post #5 of 5 Old 10-14-2013, 10:41 AM Thread Starter
DaSupercharger
1990 XJ Cherokee
Okay, so update time! In some cussing and swearing at the regulator while I tore my door down, took out the window, trim and everything, I realized that I had to drill out the rivets to get the damn regulator out?! (Doh!)
Predictably, I started to panic like a 14 year old tween and went to my basement to get a 2x4 to keep my window up and shut it up for good and be done with it.
HOWEVER, when I walked out, and looked down the window channel from above, I saw that there was a small shiny pin sticking out of the regulator. And I'm like, "gee, that seems out of place."
So in good ol' redneck fashion, I picked up a socket wrench and used it as a hammer to smack the pin back into the regulator and VOILA!!! Damn thing started working as good as new!
Problem solved and lets see how long that regulator will last. Its already taken 24 years of abuse, maybe it'll handle 24 more
waggy , wagoneer , window removal
