need help - JeepForum.com
post #1 of 9 Old 05-11-2013, 07:31 PM Thread Starter
shouser45
2009 JK Wrangler
need help
1999 jeep Cherokee 2dr 154xxx on clock
replaced
plugs
wires
cap
rotor
coil
fuel line
fuel rail
fuel injectors
tps
iac
purge valve
ldp
charcoal canister
when driving as long as im on the gas the jeep is fine but as soon as I let off the gas the idle jumps from 800 to 1200 its a steady jump even when I come to a stop the jeep will idle fine this is only while driving im about to burn this f'r to the ground I do have a new cps I didn't get to install yet
plz help ive searched
shouser45 is offline
post #2 of 9 Old 05-11-2013, 09:12 PM Thread Starter
shouser45
2009 JK Wrangler
replaced
plugs
wires
cap
rotor
coil
fuel line
fuel rail
fuel injectors
tps
iac
purge valve
ldp
charcoal canister
Bumppppp
post #3 of 9 Old 05-12-2013, 11:01 AM Thread Starter
shouser45
2009 JK Wrangler
Bumppppp
Really?
post #4 of 9 Old 05-12-2013, 11:09 AM
sluff28
1975 CJ5
O2 sensors can cause this jumping idle. Not sure if this would be the issue due to good idle standing still
sluff28 is offline
post #5 of 9 Old 05-12-2013, 11:10 AM
buildin1XJ
Any Codes? Where have you been buying your sensors from? Cheap lifetime warranty sensors bought from places like advance are very well known to fail right out of the box, which ends up causing you to think all is good. Sounds like you've been throwing parts at it instead of testing.
buildin1XJ is offline
post #6 of 9 Old 05-12-2013, 11:20 AM
tnc22
Speaking of testing: vacuum leak somewhere on your intake matches your symptons bang on.
tnc22 is offline
post #7 of 9 Old 05-12-2013, 11:21 AM Thread Starter
shouser45
2009 JK Wrangler
All parts thrown at it needed to b replaced prolly could have held off on purge valve an charcoal canister all vac lines r good to it was all part of the turn up just don't know why I have n idle issue
post #8 of 9 Old 05-12-2013, 11:35 AM
tnc22
Ah, but testing! Did you go looking for leaks on your intake i.e. Around the gaskets with a spray or stethescope? Did you check all the individual components that have a vacuum line routed to them?
The basic idea is if there is air getting in somewhere, the engine will act just like having your foot lightly on the throttle. Speaking of which, check that nothing is interfering with your throttle plate or cable or gas pedal. Had my floor mats catch me like that once, holding the gas pedal slightly applied.
tnc22 is offline
post #9 of 9 Old 05-13-2013, 07:13 AM Thread Starter
shouser45
2009 JK Wrangler
Pulled code p1494 where so I start with this?? I have checked everything what am I missing??
