Need heater core help! Please help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Need heater core help! Please help!
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineZONE 4.25" combo lift for TJ available at Rockridge4wTeraFlex Now at Rockridge 4WD! BEST DEALS around!
Unread 01-07-2015, 05:14 PM   #1
Workman13
1997 XJ Cherokee
I have a 97 Jeep cherokee 4.0. I believe my heater core was going out but not sure. I talked to a couple mechanics who believe there could be another issue. I have recently changed the thermostat and water pump. When first turning the heat on it has a sweet smell like antifreeze. after a minute or two it goes away. The heat never gets very warm though. I checked the passengers floor board and it is damp but does not smell like antifreeze. I have checked the coolant level to insure it is good for cold temps.
Any ideas on if the issue is the heater core or something else? I dont want to spend the money fixing it if that is not the issue.
Workman13 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 06:49 PM   #2
DiggsBakes
Sounds like my WJ when the core went on it. Do the windows fog while defrost on?
How's the engine temp?
DiggsBakes is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 07:00 PM   #3
brute66
Your heater core may have a very small crack that closes as it warms up. If you're not getting enough heat out of it, that could be another indication it's time to replace the core.
brute66 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 09:32 PM   #4
Workman13
1997 XJ Cherokee
The windows don't fog up yet. The engine temp stays around 210 maybe a tad under it. I plan pulling the carpet back and stuff this weekend and get a good look at it to see if I can find a leak.
Unread 01-08-2015, 12:00 PM   #5
AZ Jeff
2014 JK Wrangler
Your description of the smell of coolant when the heater is first turned on is the PRIME symptom of a core with a slow leak. It needs to be fixed for reasons other than just the annoying smell. Here is why:
An XJ's cooling system is it's Achille's Heel. It MUST be in virtually PERFECT condition to prevent overheating in warm weather. A heater core with a "pinhole" type leak will not allow the cooling system to hold pressure. If it won't hold pressure, it's a candidate for overheating in warmer weather.
I recommend you fix this ASAP.
AZ-Jeff
1992 XJ -- stock (RIP)
2000 XJ -- lots of basic mods. Sold to fellow forum member. I miss it.
2014 JK -- the project is just starting!
AZ Jeff is offline   Reply With Quote Quick reply to this message
