Quantcast Need advice on replacing A/C Compressor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Need advice on replacing A/C Compressor
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 06-26-2007, 06:56 PM   #1
pharunk
1997 XJ Cherokee
I had my AC charged, only to find out the compressor is kaput. I've seen some listed on ebay and parts stores, generally starting around 250 and going up to 500. I have no problem buying remanufactured w warranty. Seeing brands called Replacement, Factory aire, Ready Aire, and others.
Any success or horror stories on buying these things?
Recommendations?
Any experience with Jeepair.com? They seem to have the best pricing - rebuilt for under 200, new for under 300
for the record, I have a 97 Cherokee Sport, 4.0 ltr engine. Compressor in there now is a sanden 4691
pharunk is offline   Reply With Quote
Old 06-27-2007, 12:24 PM   #2
AZ Jeff
If I were planning on replacing my compressor, I would choose an OEM type, either new or reman.
OEM for later XJ's is a Sanden.
Choosing another brand other than Sanden may (or may not) result in fit issues on the existing mounting bracket and hoses.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Glock Forum
