Quantcast Mystery hose? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Mystery hose?
Free Shipping on all Engo Winches Continues...starting at Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineONBOARD-AIR.COM: Economy OBA System
JeepForum Membership Drive - Reduced Premium Membership For a Short Time Only
Old 07-29-2010, 08:51 PM   #1
habbyguy
Mystery hose?
Hi, all... I was just crawling under my '96 XJ when I noticed what looks like a vacuum line and a broken check valve hanging down beside the right side of my (MT) bellhousing. It's bundled with a couple other cables in the area (speedo and something else).
It appears the check valve broke and the vacuum line ended up dangling down between my bellhousing and the right side upper control arm.
It's getting dark - and it's raining (a very unusual situation in Arizona...) and I couldn't see anything that looks like it should be connected to that line.
Any ideas?
habbyguy is offline   Reply With Quote
Old 07-29-2010, 09:38 PM   #2
McLovin
1991 XJ Cherokee
sounds like the breather valve for the tranny?
http://jeep4playoffroad.org/index.php --your local oregon coast club
McLovin is offline   Reply With Quote
Old 07-29-2010, 09:38 PM   #3
casperbrown
1993 XJ Cherokee
maybe transfer case ? 4x4 vacuum line possibly....
casperbrown is offline   Reply With Quote
Old 07-29-2010, 09:50 PM   #4
D_ROY
probly the vaccum line for the transfer case. see if it will engage. if the transfer case was swaped with a np231, which is common, the vaccum hose is not used i believe
D_ROY is offline   Reply With Quote
Old 08-09-2010, 07:45 AM   #5
habbyguy
Well, I finally had time to check out the hose in the light... looks like it's just a vent hose for the transfer case. What I thought was a broken check valve seems to be just a one-way vent. No wonder I couldn't find the "other end" of the vacuum line...
I do still have a vacuum leak somewhere (my A/C blows only through the defrost vents when I'm accelerating of going up a hill)... I couldn't find anything obvious in the engine compartment... any ideas?
Old 08-09-2010, 10:10 AM   #6
cbordea
I had a similar issue.
AC would only blow through defroster,
Cruise wouldn't work
high idle.
It was a vacuum hose on the intake.
88 MJ I6 4x4 Stock my hauler - Sold
98 XJ I6 4X4 Stock my son's DD
06 12V Purple Barbie Jeep my daughter's DD :-)
cbordea is offline   Reply With Quote
Old 08-09-2010, 02:37 PM   #7
cornbrizzle
1992 XJ Cherokee
If you have a small propane torch , turn the gas on but don't light , start motor and run tip of torch along the vacume hose and when your idle rises there's your vacume leak, vacume will suck the propane in and it will make the idle go up .
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline   Reply With Quote
Old 08-09-2010, 03:19 PM   #8
keepishop
keepishop's Avatar
1989 XJ Cherokee
Brizzle
kaboom?
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline   Reply With Quote
Old 08-09-2010, 03:34 PM   #9
Mkonyn
1997 XJ Cherokee
Originally Posted by keepishop View Post
kaboom?
That's what I was I thinking. Haha. Wouldn't carb cleaner be less, i dunno, potentially hazardous while delivering the same results?
Mkonyn is offline   Reply With Quote
Old 08-09-2010, 03:49 PM   #10
cornbrizzle
1992 XJ Cherokee
kaboom?
Nope, not going to happen !!!!!
Brizzle
“Don’t Tread On Me”
www.highsprings.com
Old 08-09-2010, 03:56 PM   #11
keepishop
keepishop's Avatar
1989 XJ Cherokee
Maybe I've seen too many spark plug wires arcing.
Bleed or Quit.
Old 08-09-2010, 04:04 PM   #12
cornbrizzle
1992 XJ Cherokee
All it would do is light the torch, hopefully you wouldn't do this in a closed garage, But spraying carb cleaner (also flamable) that leaves a residue that will burn all over the engene compartment seem a little more to be concerned with. The propane will drift away.
just my .02
Brizzle
“Don’t Tread On Me”
www.highsprings.com
Old 08-09-2010, 08:25 PM   #13
habbyguy
The propane (minus the explosion) is a good idea - thanks! Face it, the engine's already full of optimally mixed gasoline vapor and air... I think it can handle a little more "internal kaboom"...
I already tried using a hose (one end to my ear, the other around all the vacuum lines), with no luck. At least the leak is small enough that my cruise control works, and I get air through the lower vents most of the time (though there's always at least half going through the defrost vents). Guess I'd better find the leak before it gets worse and my A/C stops (not an option in August in AZ).
Old 08-09-2010, 10:03 PM   #14
cornbrizzle
1992 XJ Cherokee
Vacuum Check Valve Universal by Dorman - Part 47149 - Advance Auto Parts
also check the vacuum check valves , you could be just not holding a vacuum and not have a leak .
Brizzle
“Don’t Tread On Me”
www.highsprings.com
Old 08-09-2010, 10:06 PM   #15
JEEPSFORUS
1997 XJ Cherokee
some one call the fire men, hes gonna do it
JEEPSFORUS is offline   Reply With Quote
Glock Forum
