Quantcast my xj hates me - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > my xj hates me
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-03-2008, 04:09 PM   #1
xjgnar
my xj hates me
So, ive had on going problems that come and go, one being my jeep not starting until its cooled down. Im not sure what is causing this but, about a month ago my car would not start i thought I had it narowed down to the ground on the engie block. When i replaced that i had minimal issues starting it, untill recently when i drive home from school or any distance over about five miles and shut the car off i will not be able to start it untill about an hour later when the engine has cooled. every once in a while i am able to get it started by taking the enige block ground off and then re attaching it. I dont know what the problem is here its getting really old now. Any one have any Ideas?
xjgnar is offline   Reply With Quote
Old 03-03-2008, 04:26 PM   #2
CanadianJeep86
check either your crank position sensor or your Hall Effect Sensor inside the distributor, could be either of those 2
1984 Suzuki SJ410, 1.3L 5speed, soft top, spoa, shackles, bodylift, 6 offroad lights.
1988 Dakota, 318, 5 speed, 4.10's, rollbar, lowered 3".
1986 2dr XJ, 2.8, 5 speed, Bushbar,
1989 XJ, 4.0, AW4, NP231, D44, 3.73's, *Stolen*
1987 MJ Sportruck, 2.5, AX5, Rollbar, *Jeep Heaven*
1986 MJ, 2.5, T-5, bushbar, Longbox, *Jeep Heaven*
CanadianJeep86 is offline   Reply With Quote
Old 03-03-2008, 04:34 PM   #3
FlexdXJ
1997 XJ Cherokee
sounds like a starter to me. That is exactly what my Vdub did before i replaced the starter
97 XJ 4.0 AW4 NP231: BB, 31's CB, Surco Rack, , Autopals, Scangauge II, JCR tail light housings, basically Looks like JCR puked on it and some sweet hood pins! :D
FlexdXJ is offline   Reply With Quote
Old 03-03-2008, 04:40 PM   #4
tjwalker
It's the crank sensor!
tjwalker's Avatar
Your XJ will not start. But does it CRANK over fine and not start or does it NOT CRANK over at all? Need to clarify that so we can help you better....
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Old 03-03-2008, 04:44 PM   #5
firefighter1c57
SPACE FOR RENT
firefighter1c57's Avatar
coil's have been known to be heat sensitive, and ground sensitive.
piks
I bring NOTHING to the table.
firefighter1c57 is offline   Reply With Quote
Old 03-03-2008, 07:00 PM   #6
xjgnar
hey guys,
Sorry if i wasnt specific enough. When the engine acts up it doesnt even crank, i turn the key and all the electronics turn on and when i turn it the rest of the way to start they turn it on the gauges temp gauge goes all the way up and i get nothing. hope this helps. i think im going to bring it to a shop and have them look at it.
Old 03-03-2008, 07:10 PM   #7
firefighter1c57
SPACE FOR RENT
heat soked starter
piks
Old 03-03-2008, 07:16 PM   #8
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
buy a new starter. I wouldn't spend the money on a shop visit.
xjfever is offline   Reply With Quote
Old 03-03-2008, 07:56 PM   #9
tjwalker
tjwalker's Avatar
I would say the problem is either the starter, or cables/connections in the starter circuit.
Next time it happens, take a meter and see if you have 12 volts at the starter terminal. If you do, the problem is probably the starter. If you DON'T, then start working your way back towards the battery. This does smell like a starter problem though
Old 03-04-2008, 01:35 PM   #10
minitruck83
1994 XJ Cherokee
Do you have lights when it's acting up? If not check cables first.
If it turns out to be the starter overheating, might try fabricating a sheet metal heat shield to install between the starter and the nearest heat source. (engine block or header) for a longer lasting fix. Helps keep oil and grease off the starter too.
Allen
minitruck83 is offline   Reply With Quote
Old 03-04-2008, 03:12 PM   #11
xjgnar
well, i had m mechanic look at it and he thinks its the NSS, im not a mechanic but i dont know how having the engine warm would trigger the NSS not to start the car. I dont know though maybe it is that. im getting really sick of my XJ, my break that i replaced a month and a half ago due to siezing siezed up so that is another problem to add to the list.
thanks for every ones help
will
Old 03-04-2008, 04:43 PM   #12
tjwalker
tjwalker's Avatar
I suppose it could be thermal failure of the NSS. When this happens, have you tried wiggling the shift lever or tried to start it in neutral? If you have some luck with that, then definitely suspect NSS. Also your backup lights are controlled by the NSS. If you have no backup lights when the no crank occurs, that's another vote for the NSS.
You could try removing/cleaning/reinstalling but if it is a thermal failure, that might not help. Price for these varies depending on the year; if you can get a cheap one, I probably wouldn't mess with cleaning. There are also some threads about bypassing this switch. Use SEARCH function for more info.....
Old 03-04-2008, 07:27 PM   #13
xjgnar
yeah i think my XJ has it by passed, when i bought the jeep the reverse lights were hooked uo to a toggle switch that is why my machanic thinks its the NSS cause the car to do this
Glock Forum
