IS my TPS bad? - JeepForum.com
post #1 of 5 Old 03-11-2011, 12:42 PM Thread Starter
IceD
IS my TPS bad?
TPS reading .845 at idle to 3.99 at WOT my book says spec is .200 to 4.99 is my TPS bad?
IceD is offline
post #2 of 5 Old 03-11-2011, 01:52 PM
MC_wk
2007 WK
Peoples opinions on this will differ, but I would say that if you're idling okay, within the 600-1000 rpm range, you're okay. You're not throwing codes are you?
When my TPS failed last summer it was rather obvious that it had gone kaput. I was idling at 1300 rpm, but that wasn't a huge deal (I still knew I had to replace it eventually) . The major problem was that while driving on the highway, if I let off the gas, my rpms would drop well below 500, then the engine would die. I would say that when that happens, you're TPS MUST be replaced. If it's not doing that, then it's probably okay.
07 WK CRD | QD2 | GDE ECO - DPF | OME HD | Moabs & Duratracs
98 XJ | FbG | Moabs & Duratracs
96 XJ
MC_wk is offline
post #3 of 5 Old 03-11-2011, 01:59 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Yes, it is out of the normal range and should be replaced.
CJ7-Tim is offline
post #4 of 5 Old 03-11-2011, 09:32 PM
XJ Jay
The voltage at idle of my new TPS was almost .9 of a volt, and my jeep runs fine. Not sure on the volt age at WOT is, it should be closer to 4.5 volts. Unless your having a driveability issues or check engine light, I would leave it alone.
HISWhite 99 XJ Sport
5" RC/ProComp lift, Serious long arms, 33" Cooper STTs, Soft 8s, 4.56s, Aussie locked D30, LSD 8.25,discos, armoured blah blah blah, HP44/9" coming soon
HERSBlack 08 JK Unlimited X, Teraflex 1.5" leveling kit, Rubi coils 35" TSRs and 5.13s
XJ Jay is offline
post #5 of 5 Old 03-12-2011, 07:30 AM
cbordea
when mine went bad both times it wouldn't shift out of first gear.
88 MJ I6 4x4 Stock my hauler - Sold
98 XJ I6 4X4 Stock my son's DD
06 12V Purple Barbie Jeep my daughter's DD :-)
cbordea is offline
