Is my Rear Diffrential Bad????? - JeepForum.com
post #1 of 3 Old 03-21-2013, 05:33 PM Thread Starter
bds5
I was at work Wednesday and my Cherokee started having a vibration to it while Moving, by the time I headed home it was getting really bad. I thought it was probably a rear U-Joint. When I got home checked the Joints....,. they were good so I jacked up the rear tires off the ground put it in gear about 30 MPH and only 1 tire turns and you can hear the vibration from inside, Anyone know what it might be??
bds5 is offline
post #2 of 3 Old 03-21-2013, 06:29 PM
AZ Jeff
2014 JK Wrangler
On an open diff., you would expect only one wheel to turn when up in the air.
That said, if you hear a vibration, pull the diff. cover and explore.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 3 Old 03-21-2013, 06:33 PM
Motorcharge
If nothing else pull the diff cover and give us pics. It should be pretty obvious if something in there is the problem.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
