Quantcast my radio antenna - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > my radio antenna
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 08-12-2004, 01:53 PM   #1
bdhaley
my radio antenna
Hey guys,
My antenna wire is bad that goes to my radio. I open up the hood and it doesn't look like you can even get to it. Does anyone know of an easy way to realce the antenna assy?
[COLOR="DarkRed"]1998 TJ, 4 banger, 5 speed, Rusty's 2" lift, 31" BFG At KO's, AR 15x8 [URL="http://img.photobucket.com/albums/v645/harley72/MY%20TJ/TJafter.jpg"][COLOR="DarkRed"]My TJ[/COLOR][/URL][/COLOR]
[SIZE="4"][SIZE="2"][COLOR="blue"][URL="http://img.photobucket.com/albums/v645/harley72/Liberty/Liberty.jpg"][COLOR="blue"]HER KJ[/COLOR][/URL]
2003 KJ Sport 4x4[/COLOR][/SIZE][/SIZE]
bdhaley is offline   Reply With Quote
Old 08-12-2004, 02:07 PM   #2
bdhaley
bump......................
Old 08-12-2004, 02:18 PM   #3
ctavel
1990 XJ Cherokee
I think you can get to it by removing the inner fender well stuff and by removing the passanger kicker panel. Mines exposed becasue neither of those tow thigs are there on my rig anymore. Hope this helps
ctavel is offline   Reply With Quote
Old 08-12-2004, 02:21 PM   #4
bdhaley
Hey thanks man
Old 08-12-2004, 02:24 PM   #5
ctavel
1990 XJ Cherokee
no problem. But don't thank me until you get it fixed
Old 08-12-2004, 05:50 PM   #6
JoBo
Originally Posted by bdhaley
Hey guys,
Are we talking your Cherokee here? If so on my 96 there's a connection behind the plastic cover at the passanger's feet. It goes through the body behind that panel also.
JoBo
JoBo is offline   Reply With Quote
Old 08-12-2004, 09:17 PM   #7
bdhaley
JoBo
So are you saying that I can take off a cover on the passenger side and the antenna wire connects to the antenna there? What do you mean by there's a connection there? Is it easy to get to?
Thanks
Old 08-13-2004, 05:20 AM   #8
JoBo
Thanks
While cleaning my newly aquired 96 xj I had the panels off to remove the carpet. There was a connector that was appart. It's not like anything I've seen on a antenna lead before. One lead went through the side to the antenna and the other went up to the radio. My xj had it's radio stollen before I got it and so I didn't know there was a problem with it. My connector wouldn't stay together, it's spring loaded, so I put a tie wrap around it. Easyiest way to see what I'm talking about is remove the panel. The panel has places for two screws but mine only had one screw holdong it on. When putting it back on make sure you don't pinch any wires.
JoBo
Old 08-13-2004, 09:19 AM   #9
VTJeep11
Hey thanks man
i have a 96 sport also, i've had no problems with my antenna. i didn't even use an antenna adaptor when i put my new cd player in. i was actually thinking about choping the antenna i was just wondering if any1 has done that, shortened the antenna or removed it completely, and how well it effects the radio and cb.
VTJEEP11
'96 cherokee sport
straight 6, 4.0l
panasonic deck
2 memphis 5,1/4 speakers
2 10" subs in the back
K&N cone intake
future mods
Exhaust from cat back
2" or 3" lift, and tires
brush guard with winch and lights
snorkel
and more, and more, and more.......
VTJeep11 is offline   Reply With Quote
Old 08-13-2004, 09:55 AM   #10
red87cherokee
A semi-truck side swiped me with the butt-end of it's load and removed my antenna (among other damage). I've never gotten around to replacing it, so I can tell you (at least for an '87) that the reception is very iffy and weak without an external antenna. As best I can tell, I have to be within 20 miles of a strong radio station to receive the broadcast - and any interference wipes out even that limited reception.
red87cherokee is offline   Reply With Quote
Old 08-13-2004, 10:42 AM   #11
bdhaley
Thats where I am at right now. I can get a signal when I am withing a few miles of the locale radio station but after that forget it. I installed a new antenna mast but it didn't help
Glock Forum
