My oil guage is acting up and i don't think it's the sending unit - JeepForum.com
post #1 of 7 Old 04-28-2009, 11:00 PM Thread Starter
kruucks
after the engined is warmed up, my oil pressure gauge reads ~38 at idle, but anytime i hit the throttle it shoots up to ~75 or higher. what gives?
it's a 95 auto with part-time 4wd. oil change within the last 2000 miles.
kruucks is offline
post #2 of 7 Old 04-28-2009, 11:24 PM
MooseMarine
JP'N MTBR
MooseMarine's Avatar
When you rev the engine your oil pressure should rise. Normal operating psi is 40 at idle and between 40 and 120 when your engine is reved.
You are the average of the five people you spend the most time with.
_______
/| ,[____],
|---L '[]lllllll[]'
()_)-()_)--o-)_)
MooseMarine is offline
post #3 of 7 Old 04-28-2009, 11:28 PM Thread Starter
kruucks
as high as 120? i want to say that before yesterday it would only get up to about 50 or 55
kruucks is offline
post #4 of 7 Old 04-29-2009, 07:29 AM
firecontrol933
If you're talking about the electric dash guage....... does it stay steady at the higher pressure or does it go back down after a few seconds?
The electrical connection to the sending unit may be loose or even a problem with the sending unit. If you disconnect the plug from the sending unit the guage will max out.
Just replaced a sending unit on one of our jeeps. 96. And found out that there are 3 different sending units. And wouldn't you know it, they store gave me the 2 pin version when I needed the 1 pin. They're NOT interchangeable.
firecontrol933 is offline
post #5 of 7 Old 04-29-2009, 07:40 AM Thread Starter
kruucks
the gauge responds directly to RPMs/throttle. it spikes when i'm on the gas, then immediately goes to normal when i let off
kruucks is offline
post #6 of 7 Old 04-29-2009, 09:08 AM
TheNerd
TheNerd's Avatar
My '87 just started doing the same thing.... I bet the swine flu has something to do with it.
Seriously though, I don't get any warm & fuzzies from seeing the oil pressure show close to 80.
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
post #7 of 7 Old 04-29-2009, 10:54 AM
cbordea
you might have already done this but check your oil level to make sure someone didn't add to much oil or you are getting coolant in there or something to increase your oil volume.
I know most jeeps I am familiar with have about 15PSI at idle and about 40PSI at highway speeds.
My son's started acting freaky so i bought a new sender from Advance Auto. I know it is better to get from the dealer but i was in there an they said if it didn't work i could bring it back.
I changed them and guess what,it didn't work. But when i plugged in his old one again it has worked fine for a few months now. Not sure if the elec plug cleaned itself plugging and unplugging or if there was something on the unit itself.
Anyway they took it back with no problems.
cbordea is offline
Oil Sending Unit? SouthernChick XJ Cherokee Technical Forum 5 08-11-2008 06:18 PM
Oil sending unit 96_XJ_Country XJ Cherokee Technical Forum 16 08-15-2006 10:34 PM
oil pressure sending unit, coolant temp unit h2rescue XJ Cherokee Technical Forum 6 01-31-2006 10:23 PM
Oil Sending Unit. wipedawg XJ Cherokee Technical Forum 4 08-22-2004 09:56 AM
Fuel Guage acting up... cmassey_2001 XJ Cherokee Technical Forum 8 08-07-2004 02:07 PM
