Quantcast My o2 sensor wiring got ripped off by the DS. Anyone have a photo of how its routed? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > My o2 sensor wiring got ripped off by the DS. Anyone have a photo of how its routed?
Old 11-22-2009, 02:26 PM   #1
Jameslol
I dont feel like dumping 75 dollars for a new o2 sensor to get this one ripped apart by the driveshaft again, not sure how it ran prior without getting ripped out
So if anyone could give me an idea or 2 or a photo of how its ran stock that would be awesome.
Thanks in advance!
Sorry forgot to add its the o2 sensor after the cat.
Black 1996 Jeep Cherokee Sport, 4.0, 4WD, NP231.
31 inch Yokohama Geolanders.
3" Rough Country AAL Kit. ZJ tierod.
C4x4 Front tow hooks.
Nates 4x4 rear bumper w/receiver and shackles
Iron rock offroad double shear adj trackbar
Jameslol is offline   Reply With Quote
Old 11-22-2009, 03:43 PM   #2
Ed Rico
I shot a few pics under my '97 XJ, not the greatest but should give you an idea. There is a plastic bracket on the passenger side tunnel, the harness from the engine compartment runs along the tunnel to this bracket. A "christmas tree" fastener at the connector to the rear O2 sensor locates the harness and connector to the plastic bracket. Most likely your plastic fastener or the plastic bracket broke and allowed the wiring to move over and contact the spinning driveshaft. You can see in the pics I added a couple of zip ties to help keep the wiring up close to the plastic bracket.
BTW unless your upstream O2 sensor is fairly new, I'd suggest you relocate your current upstream sensor to the downstream location and buy a new upstream sensor as opposed to just buying a new downstream sensor. The 2 sensors are physically and electrically identical but the connectors are different and you can't just plug into the harness in the other location. If you move your upstream sensor to the downstream position, you'll have to cut the connector off the old upstream sensor and replace with the one from the old downstream sensor. I mention this because a new upstream sensor will make a bigger difference in the way your 4.0L runs and even with some miles on it, the old upstream sensor will work fine for monitoring cat efficiency if you move it to the downstream location.
Hope this helps.
Index of /edrico/2009-11-22 XJ Rear O2 sensor
-Ed Rico
Ed Rico is offline   Reply With Quote
Old 11-22-2009, 03:45 PM   #3
gistecknician
Are you referring to the front or rear o2 sensor?
gistecknician is offline   Reply With Quote
Old 11-22-2009, 03:46 PM   #4
gistecknician
I have pics of the front if that is the one you are looking for.
Old 11-22-2009, 03:47 PM   #5
Stout95YJ
2003 WJ
yeah this has happened to me twice such a PITA
2003 WJ 4.0 - 2" BB - 255/75 on 17" JK Moabs - Projector's with 6000k HID's - 236k and counting
1996 XJ trail rig - sold
"Speed has never killed anyone, suddenly becoming stationary... That's what gets you." - Jeremy Clarkson
Stout95YJ is offline   Reply With Quote
Old 10-10-2010, 08:08 PM   #6
rtm
help!!
hey guys,
first posthere
hope you can help
I have a 1999 jeep grand cherokee 4.0 L six
the O2 sensor wiring is just hanging (downstream)
someone put a universal sensor in,
but it is wired wrong
I have (on the sensor side)
two white wires
a grey wire
a black wire
on the factory harness side
black/grey? stripe
black/pink stripe
black / white stripe
green/red stripe
anyone know how I should connect these ?
thanx in advance
RTM
rtm is offline   Reply With Quote
Old 10-10-2010, 11:33 PM   #7
Wiskey
1991 XJ Cherokee
Welcome!
I don't know,... but someone here probably does - you would be better off starting your own thread though, your post would get more traffic that way.
Whiskey
[QUOTE=Rescue XJ;1414400]Seafoam. . . Its the closest thing to an enema for your engine.[/QUOTE]
Wiskey is offline   Reply With Quote
Old 10-11-2010, 03:16 PM   #8
rtm
thanx 4 advice
I started a new thread
Glock Forum
