Quantcast My New XJ Project - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > My New XJ Project
Old 10-13-2004, 04:32 PM   #1
MaddieXJ
My New XJ Project
Well, I started working on a new Cherokee about a week ago.
Heres the specs: 1990 Xj, 4.0, AW4, NP231. Its a base model 2 door.
Here it is with the tiny little 205s:
And here it is with the Camo Paint, TJ Flares, and 32" BFG. And lots of missing sheetmetal!
I currently have zero lift. In fact, with the way the stock springs are sagging I would say I have some negative lift.
I plan to add an old 3" lift for a temporary solution. Then comes the 6.5" lift, Ford 8.8, 4.88 gears and either 33" or 35" tires.
"Is your head up your *** for the warmth?"
"If you need it and you dont have it you sing a different tune"
1996 XJ 2-Door
4.0, AX-15, NP-231
RE custom 7" lift, 33" Interco Trxus MT's
ACOS, Ford 8.8, AA SYE, Tom Woods Shafts,
Rusty's skids, Rigid Hitch, Custom Bumper, Ramsey Winch
Mopar Performance sounds good with a Flowmaster 40!
'89 XJ Laredo "Project: Minnesota XJ" (RIP)
1990 XJ (SOLD)
4.0, Auto
Camo, TJ flares, 3.5" lift and 32" tires
MaddieXJ is offline   Reply With Quote
Old 10-13-2004, 04:55 PM   #2
verrive
Looks good
1992 Cherokee Briarwood 4.0L
ARB Bull Bar/Warn XD9000
4.56s D30/ARB D44/Lockrite with Discs
4" OME/Teraflex Lift with 33x12.5 BFG M/Ts
KOR Rock Rails and JKS Discos
verrive is offline   Reply With Quote
Old 10-13-2004, 09:33 PM   #3
scubaguy19
that looks good, anytime you want to work on my jeep go ahead, i'd even let you paint it camo
2001 5.0 awd exploder - dd
$400 90 laredo xj - beater
91 Limited XJ - missed
[QUOTE=Centrax]There should be a warning label on the sun visor of those H2's "Warning, not intended for off road use." It's not even a REAL Humvee, it's just a Chevy Tahoe with fugly body panels.[/QUOTE]
thats hilarious
scubaguy19 is offline   Reply With Quote
Old 10-13-2004, 09:39 PM   #4
DeathCrush
two doors rule
did you do the paint job yourself? looks really good
[SIZE=5][COLOR=darkslateblue]88' XJ Cherokee [/COLOR][/SIZE][COLOR=darkslateblue][SIZE=4][I][B]Pioneer[/B][/I][/SIZE][/COLOR]
4.0L engine "Low Output"
BA10/5 5-spd. tranny
172,000+ miles
1.5" boost up front, nadda" in rear :(
235/75 Goodyear MT/Rs
Tomken Rear Bumper w/ Tire Carrier
Custom Camouflage Interior
-->[URL]http://www.angelfire.com/theforce/herzeleid76/[/URL]
[URL]http://www.keiraknightley.com/[/URL] yea yea, she's worth it
DeathCrush is offline   Reply With Quote
Old 10-13-2004, 09:42 PM   #5
onlyinajeep07
you said u had no lift at all with 32's, how did u manage to trim soo much in the back??? Also if u have a write up on the trimming or if u could send me one id appreciate it man. Mark
onlyinajeep07 is offline   Reply With Quote
Old 10-13-2004, 09:52 PM   #6
mbood82
Yeah, I'd like to see any pics you have of the trimming in the back... I'm gonna be doin that soon...
'99 Jeep Cherokee - RE 3.5" SuperFlex with 32s
'06 Dodge Magnum R/T
'03 Toyota MR2 Spyder
mbood82 is offline   Reply With Quote
Old 10-13-2004, 10:35 PM   #7
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
You can trim a bit more on the 2 door than the 4 doors. On the 4 doors, the rear wheel well is just too damn close to the back of the back doors.
Looks good. Makes me want a door door to play with as well.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 10-13-2004, 10:37 PM   #8
mbood82
That's what I figured, just gotta reweld the seams back together...
Old 10-13-2004, 11:20 PM   #9
MaddieXJ
The Paint job I did myself. It is three coats of Krylon camo paint. The one with the camo Jeep on the can. Was a total of about $60 bucks with materials. And about 1 day to paint and 3 to prep the body.
TJ Flares:
Actually, I did not trim past the pinch seam in the rear fender.
I used Jasons method from Jeepin.com
I just unbolted the rear flare, used a sawzall to cut little strips about 1.5 inches apart and then I hammered it back underneath the fender lip. Works perfect.
These pictures should explain it better. Although these are on a 4 door, not my Jeep. On a 2 door you end up with an even bigger wheel well.
Then I just marked and drilled the holes for the TJ Flares, popped off the inside panels and bolted the flares to the body with some stainless steel hardware.
Let me know if you have any other questions.
1996 XJ 2-Door
4.0, AX-15, NP-231
1990 XJ (SOLD)
4.0, Auto
Old 10-13-2004, 11:23 PM   #10
xjj33p3r
I'm going to be posting a write up of how to trim 4 door rear fenders and make it look good. On one fender, I've got 11" of clearance with a 34" tire and 6.5" lift. That's pretty damn good if you ask anybody. Check it out in about 2 days when everything is done and all pretty on my jeep
xjj33p3r is offline   Reply With Quote
Old 10-13-2004, 11:25 PM   #11
xjj33p3r
How can you end up with a bigger wheel well if you did the same thing as Jason? I'm not doubting you, but it doesn't make sense because you said you didn't go past the pinch seam
Old 10-13-2004, 11:29 PM   #12
verrive
I assume the 2 doors have a bigger wheel well. Also, you don't need 7.5" of lift for 34"s, just be a man about it. Cheap fit 36"s on 3" of lift :P
Old 10-13-2004, 11:53 PM   #13
xjj33p3r
I have 7" of lift... and I am a man about it, a smart one. I don't need to waste money on tires that are too big that will shred up on a lift that is too small. I'd rather do the correct thing. And if 2 doors do have bigger wells, it wouldn't matter. He only trimmed up to the lip, which is the same size as the 4 door.
Old 10-14-2004, 12:05 AM   #14
verrive
Just for reference Cheap doesn't shread his tires on his lift, he just cut an insane amount. With the right trimming you could fit 37"s with as much lift as you've got and it'd be fine.
Old 10-14-2004, 10:51 AM   #15
MaddieXJ
On the two door you can cut the strips longer. It still holds the pinch seam together, but you can fold those longer strips backwards and it makes a bigger wheel well.
You cant do that on a four door because the rear door is in the way.
And if you do it carefully and do it the right way the folded peices will fill any gaps that occur. Its a little tricky but it worked for me.
You might want to run a line of caulk between the inner and outer fender on the inside. That would make it weather tight. Mine was close enough I didnt need that. I just por-15 the bare metal and then coated the underside of the wheel well with some undercoating. That should prevent anything leaking in through the cuts.
I might have been misunderstood when I said I didnt cut past the seam. Sorry for any confusion. What I meant is I didnt cut it completly off, so I didnt have to weld anything.
Brian
1996 XJ 2-Door
4.0, AX-15, NP-231
1990 XJ (SOLD)
4.0, Auto
Glock Forum
