#1 | |
my new 2000 sport
Hello jeepsters.. i just bought a 2000 cherokee sport.. 4.0L with 36,173 miles on it.. im wondering what oil to start putting in it. should i stick with regular oil or switch to synthetic. (sp) ??? i didnt get an owners manuel.. soo also what weight do i use? thanks for any help.. i love this thing so far..
#2 |
Hi and welcome. I changed over to synthetic at 30k on my Cherokee and I highly recommend it. I started out with Castrol Syntec and switched to Mobil1 after reading comparisons. Changes are every 5000 miles for me along with lubes. Mobil1 synthetic grease for all the zerks. If your Jeep didn't get a complete fluid change at 30k you may also consider putting synth gear oil in your diffs and synth ATF in your transfer case (if 4WD) as I did. Don't forget to service your auto trans (or 5speed) also. Very important if you want to keep your Jeep alive. Get your hands on an owners manual and a Factory Service Manual (Ebay) as soon as possible if you plan on doing your own work. ps. Weight of oil depends on climate. Check with your dealer or ask here on the forum.
#3 |
ok so basically change everything now... all fluids. really .. just to be safe?
#4 |
Where do you live? Climate can help you decide which oil to run.
If you have really hot weather and you drive your jeep a lot in it, you should probably look into synthetic oil. For example, I live in Oregon so there is no real need for me to use synthetic... Another thing, with fluids I am a fond believer of if it came from the factory like that, it should probably stay like that. If you keep the recomended fluids you will be perfectly fine. Last edited by crookedletterd; 06-22-2003 at 08:31 PM.. |
#5 |
The Post man
Welcome Woodys2000 and sbxj!
If you live in the US, you can order an owners manual (or factory service manual) by calling 1-800-890-4038. It says owners manuals are only $6 + tax.
The owners manual states that 10W-30 is the preferred grade of oil to be used, however 5W-30 could be used when outside temps fall below 0* F. I use Mobil 1 synthetic 10W-30 in mine year round. Since this is a new vehicle to you, yes it is a very good idea to have all the fluids changed. Even if they were changed recently by the previous owner it never hurts to put in fresh oil again. And you know FOR SURE that the fluids are changed. Synthetic is very good in the differentials, and I use synthetic ATF for the transfer case as well.
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#6 |
Thanks for the welcome Eric. BTW, what a difference the Mobil1 ATF made in the shifting of my 242...smooooth. Expensive, but worth it.
#7 |
The Post man
Always glad to have more 2000 owners in here!!! Yeah my 231 (with synth ATF) shifts very smooth as well!
#8 |
Do synthetics have a longer life span sitting unused than regular oils? Im talking that how you either change the reg oil every 3000 miles and X months.
Im considering changing my 97 with 88K to synthetics now that its a weekend only truck and that makes the synths more affordable. So , what do yall say. What is the changeover procedure also?
Eddie Crab3 '97 XJ Nuttin Special |
#9 |
yes if i can remember correctly i believe it is every 5000 or 6000 miles instead of the normal 3,000.
#10 |
ok well my next oil change i might look into synth. but what about the auto tranny... and the differential and all those fluids as well? every 30,000? if so im at 36,000 and leaving for along trip in a week what should i do .. just check it and make sure everything looks good or go ahead and get them drained and changed? thanks for all the help..
#11 | |
#12 | |
#13 | |
The Post man
There is no real "change-over proceedure". You can switch to synthetic and back again if you like, or mix it with your regular oil (I don't know why you would) since its fully compatible. Some people will claim that synthetics will cause seals to leak on older engines with a lot of miles on them. As far as I know this is false. Synthetic oil will not "cause" leaks in any engine. If it starts to leak it may be because there are leaks allready present that are clogged with crud. The detergents in the oil may loosen the crud and the leak starts.
#14 |
ok well i called around to some places and to get most of the 30,000 mile maintence done it will be $200-$300 ... what do ya think.. are these things that I could really do? Im switching everything over to synth. I bought the Haynes manuel. just wondering if i should even try to mess with it. I dont want to mess up my new ride before i get to go on a trip in it.. thankss....
#15 |
I say yes, you can all of it yourself, just need a small amount of tools and a weekend.
Let me think, the maintenece should be ok, change all fluids/flush radiator change belt and inspect hoses. change oil and air filters change plugs and plug wires. inspect and replace brakes and pads rotate tires some fuel system cleaner clean throttle body change wiper blades grease all fittings Im sure im forgetting something, but I think you can do it all, and you will feel utterly satisfied. And you will come way under the $300 price. But, if you dont have the time or tools or pataience, thats why there is mechanics outthere.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
