My JEEP is stuck in first gear. HELP - JeepForum.com
post #1 of 2 Old 05-26-2011, 08:00 PM Thread Starter
ElevatorguyNY
My jeep has been downshifting a little rough lately, but today it wouldn't shift into second. I tried everything: I revved up to 5000 rpm, manually shifted to second, neutral to second while moving etc, still no luck. It just will not shift into second. I replaced the output shaft speed sensor and that did not help either. Any ideas would be greatly appreciated.
ElevatorguyNY is offline
post #2 of 2 Old 05-27-2011, 12:29 AM
keepishop
1989 XJ Cherokee
Few people here will be able to help. You're in the normal cherokee section, you want to ask the GRAND cherokee guys.
Possibilities I can think of are a bad connection, a bad transmission computer, or a bad solenoid.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
Speedo gear stuck CharlieMopps XJ Cherokee Technical Forum 1 11-13-2008 05:54 AM
stuck in gear mountaineerX XJ Cherokee Technical Forum 5 02-06-2008 06:33 PM
Transmission stuck in gear Jeepthing88 XJ Cherokee Technical Forum 4 12-25-2007 08:58 AM
stuck in 1st gear MetalHead88 XJ Cherokee Technical Forum 3 08-26-2006 12:07 PM
4lo stuck in gear? kernalklink XJ Cherokee Technical Forum 3 01-25-2006 03:08 PM
