My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs - Page 6 - JeepForum.com
 10Likes
post #76 of 3678 Old 07-25-2013, 04:30 PM
mschi772
1997 XJ Cherokee
I'm using a slightly earlier radiator that has a port in the drivers side tank. I'm not sure what year they stopped doing it, but the aux fan used to be controlled by a thermal switch in the rad tank. I'm using one of those rads and mounting my switch there. In every other way it is an appropriate rad. It is an open system, post-Renix radiator.
You could also use a couple brass fittings and a T to put a switch in the heater hose by the stat housing.
Despite being a fin probe, DC Controls controllers are awesome and not to be dismissed as just another fin probe controller.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #77 of 3678 Old 07-25-2013, 04:30 PM
Newtons3
Newtons3's Avatar
I have one temp sensor for the fan on my Cherokee in a second hole I drilled and tapped to 1/8 NPT in my thermostat housing. I have another in a spun aluminum housing halfway up my upper radiator hose in my Wrangler.
http://www.jeepforum.com/forum/attac...1&d=1374791243
Newtons3 is offline
post #78 of 3678 Old 07-25-2013, 04:34 PM
Newtons3
Newtons3's Avatar
Originally Posted by Charley3 View Post
What is a Scanguage?
Here is mine reading MAP, TPS, Intake Air Temp, and Coolant Temp.
http://www.jeepforum.com/forum/attac...1&d=1374791685
Newtons3 is offline
post #79 of 3678 Old 07-25-2013, 05:17 PM
ninjakid
1987 YJ Wrangler
Originally Posted by mschi772 View Post
I'm using a slightly earlier radiator that has a port in the drivers side tank. I'm not sure what year they stopped doing it, but the aux fan used to be controlled by a thermal switch in the rad tank. I'm using one of those rads and mounting my switch there. In every other way it is an appropriate rad. It is post renix and for the open system.
Despite being a fin probe, DC Comtrols controllers are awesome and not to be dismissed as just another fin probe controller.
Is there any possibilty that a radiator switch will show slightly lower readings compared to something in the head or housing?
Our xj is a 96 and it only has the probe in the housing.
I'd guess that non obd2 vehicles had them in the radiator.
Late year thermostat housings are dirt cheap on ebay if you ever wanted to try a sensor in it even if its just to compare temperature and when it kicks in.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is online now
post #80 of 3678 Old 07-25-2013, 05:22 PM
ninjakid
1987 YJ Wrangler
Forgot to multiquote.
Does that show mpg correctly for your jeep?
Been considering getting one to use in both the xj and our work truck plus my yj once I finish it.
I've been using torque to monitor our jeep since it is obd2 and it reports everything accurately except mpg.
As much as I wish I know I'm not getting 40 mpg cruising and 60 going downhill.
It displays an absurdly low fuel flow number at all times.
Something like 0.5 gph cruising at 40.
post #81 of 3678 Old 07-25-2013, 05:34 PM
mschi772
1997 XJ Cherokee
Probably, but I'm using a sensor with lower than usual temp cutoffs to compensate for the cooler temp in that tank vs the stat housing.
mschi772 is offline
post #82 of 3678 Old 07-25-2013, 05:38 PM
Newtons3
Newtons3's Avatar
Others have reported good success with it for MPG reporting. The math is simple so I don't use it for that. I find it much more useful to monitor my engine load and operating parameters. I assume it will do well if you follow the instructions for setting that up and are accurate about it.
Newtons3 is offline
post #83 of 3678 Old 07-25-2013, 05:40 PM
Newtons3
Newtons3's Avatar
I have run a switch in the radiator (inlet side) several times on different vehicles. I just adjust my sensor for the temp I need. I try to order my radiators with three 1/4" ports in the inlet tank JIC I need them.
Newtons3 is offline
post #84 of 3678 Old 07-25-2013, 05:53 PM
Syncityj
I have mine dialed in for mpgs and it's typically close. You have to set your correct speed on the scangauge, if you have re geared or used different tires I think your speedo will be off a few mph. You also have to fill your tank till capacity, meaning until it clicks once. And then run it till about 1/4 remaining, then fill it again. If you put 20 here and 10 there and fill up over here the scangauge won't be accurate. Last time I filled up, I averaged 14.1 mpgs in a 5.2 ZJ 3.5 inch lift and 31's.
Also the scan gauge is able to be used in different cars.
Syncityj is offline
post #85 of 3678 Old 07-25-2013, 06:02 PM
wj4play
Long time ago I read about smokey yuknics 50+ mpg fiero - might want to watch for some ideas
http://youtu.be/Qg8oJXcWjnE
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #86 of 3678 Old 07-25-2013, 06:44 PM
Newtons3
Newtons3's Avatar
Smokey Yunick is a hero of mine. I studied that Fiero hot air engine and read everything published about it. Don Garlits has it in his Drag Racing Museum in Ocala Florida. When I was there two years ago, the lady in the museum opened it up for me so I could have a peek. You should stop and see it if you're ever in the area. Incidentally, they also have his Octane Motor in the front of the same building. Amazing stuff.
Newtons3 is offline
post #87 of 3678 Old 07-25-2013, 06:57 PM Thread Starter
Charley3
Yes. Guaranteed.
Another problem with reading temp at radiator is the radiator is the last part of the cooling system to know what the temp is.
Reading at stat housing gives much faster response time for turning on fan when engine gets to hot, IME. That gets the fan on much sooner when things start heating up (like in traffic jam, or off road). It also gets fan shut off sooner after engine cooled back down. So much less temp swings.
I base that on have had my Wrangler setup both ways. It had an aftermarket electric fan. For a while I had a pro e in the radiator. It was unsatisfatory. So I had thermostat housing drilled and tapped and installed a screw in sensor for the thermostat housing. Then it worked good. Much faster response times for turning fan on and off. Much less temp swing. With screwin sensor in stat housing it worked as good as my Buick OEM electric fans in my car.
In hind sight, I could have put an XJ stat housing on the Wrangler, instead of drilling and tapping the Wrangler stat housing. However, the screw in sensor in stat housing worked great. I bought the screw in sensor kit from Flexalite.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #88 of 3678 Old 07-25-2013, 07:18 PM Thread Starter
Charley3
That will compensate for temp diff, but not for the lag time. A sensor in stat housing gives much faster response times when fan is needed. IME
Charley3 is offline
post #89 of 3678 Old 07-25-2013, 07:21 PM Thread Starter
Charley3
This magic you speak of impresses me. I want one.
Charley3 is offline
post #90 of 3678 Old 07-25-2013, 07:40 PM
Newtons3
Newtons3's Avatar
This is true. I would actually prefer one in the head. Preferably ahead of the thermostat housing. I've had them all over and I've actually found that the head is the best place for a temp sending unit for a gauge. My adaptor in my upper radiator hose has proven to be ideal for my electric fan. It senses what is actually going to the radiator and works well.
http://www.amazon.com/ScanGauge-Auto...ords=scanguage
Newtons3 is offline
