My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs - Page 42 - JeepForum.com
 10Likes
post #616 of 3708 Old 08-29-2013, 05:01 PM
ninjakid
1987 YJ Wrangler
I'm gonna try the jimmy air dam extension.
Maybe it won't affect mileage but I've never tried it myself and since its cheap enough I'll give it a shot.
I'll be going to a jeep swap meet and u pull it this weekend anyways.
Plus experimenting is fun even if it does not do what I want.
If I can't find one at the junkyard I'll just order it from rock auto.
$7 plus 17 to ship from there (pn GM1090104)
Need something to do until I can fix my mtg2500 to diagnose some electrical issues on it anyways.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #617 of 3708 Old 08-29-2013, 05:05 PM
Newtons3
Newtons3's Avatar
Be sure to let us see and hear about the results.
Newtons3 is offline
post #618 of 3708 Old 08-29-2013, 10:37 PM Thread Starter
Charley3
Originally Posted by Newtons3 View Post
Sorta lends perspective to my mileage claims, doesnt it? I really havent accomplished much.
I don't understand your meaning. I'm confused.
I wasn't criticizing you. Sorry if I came across like that.
My highway mileage claims are from when I (try to) stick to level ground to the extent possible. I can't avoid "bumps" (some up to 100 feet high) on freeway, but I can avoid hills (anything taller than 100 ft) if I drive on I-5 parallel to Columbia River. That is an almost level freeway for about maybe 150 miles (before it enters high mountain passes). That's as level as it gets for a highway around here. So in other words, I can keep it fairly level for a gas mileage highway test by driving only North or South. Any other direction puts me immediately onto hills and soon onto mountains.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #619 of 3708 Old 08-29-2013, 10:47 PM Thread Starter
Charley3
That air dam can be purchased for $7 + $17 = $24 new from RockAuto.com?
Wow. I'm on it! Will be ordering tonight. Thanks for posting part number and source.
Edited in Later: With shipping to my zip code the total is $39.66 at RockAuto.com. I found it cheaper on Ebay for $32.80 with Free shipping. Just ordered it now!
I love cheap mods! Especially when (IMO) they have a good chance of working!
Thanks again for posting part number. Made it easy to find on RockAuto, Amazon, and Ebay.
Charley3 is offline
post #620 of 3708 Old 08-30-2013, 05:29 AM
ninjakid
1987 YJ Wrangler
Wow it costs double to ship to you?
Most their warehouses are on the west coast so I figured shipping wouldn't be that much different for anybody else.
I was wrong apparently.
At least you found something cheaper than that.
Sent from my SAMSUNG-SGH-I747 using JeepForum
ninjakid is offline
post #621 of 3708 Old 08-30-2013, 06:25 AM
Newtons3
Newtons3's Avatar
No offense taken or meant. I was serious. When taken in context, my mpg achievements are far less than you guys with hills, mountains, and regular cold weather.
Newtons3 is offline
post #622 of 3708 Old 08-30-2013, 06:56 AM
JMH21814
1997 XJ Cherokee
Originally Posted by RacerX View Post
Uh ... I meant no contradiction, ..or offense.
I just wanted to sum up all current points (mine, yours, others)
Sorry, Racer, I didn't mean to come across as angry or offended. I just wanted to reiterate that the honeycomb tires would not be released to the public without a sidewall. No need to stress about mud, rocks, snow, or whatever other debris may get in. That's all, sorry for any confusion!
JMH21814 is offline
post #623 of 3708 Old 08-30-2013, 07:51 AM
tamnoz
Fuel Mileage
I gotta tell you, I found this thread yesterday afternoon and didn't get any work done the rest of the day. I have read about 2/3 rds of this thread and have only two questions. Do programmers help at all? If so how come no one mentioned them? If you replace the crank driven fan with electric, how many CFM do you need to match or beat it's cooling capability.
Jim
tamnoz is offline
post #624 of 3708 Old 08-30-2013, 08:00 AM
rebelbowtie
Jim
Because to my knowledge there isn't any tuning options outside of maybe stand alone modules for Jeeps. No "canned" tuner will be worth it's money. I gained 2-3mpg out of my LQ4 when I had it tuned but it was a wash out since it was tuned for 93 octane.
rebelbowtie is offline
post #625 of 3708 Old 08-30-2013, 08:26 AM
mschi772
1997 XJ Cherokee
Jim
Regarding the fan, I think the clutch-driven mechanical fan moves a max of 2700-3000 cfm. Maybe? I'm pretty sure Marcus Ohms has the figure on his site somewhere (gojeep). I know it's quite a lot; most efans don't meet or exceed it on their own. My efan setup moves about 3300, but that's because it is composed of 3 11" fans that move about 1100 each. Again, I could be a little off there.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #626 of 3708 Old 08-30-2013, 09:07 AM
tamnoz
hot fuel
Hey Newtron3, I'm curious. I come from a racing background and we're always trying to cool our fuel not heat it, also I'm constantly having a #3#4 fuel injector failure do to heat so I took heat sleave and wrapped each injector and the rail to try to eliminate this problem. Won't heating the fuel just make the problem worse?
JIm
tamnoz is offline
post #627 of 3708 Old 08-30-2013, 09:17 AM
ninjakid
1987 YJ Wrangler
Stuff on the fans is here.
http://jeep-xj.info/HowtoElectricFan.htm
I spoke to the company that built my custom 3 row radiator and he stated that our XJ's need a CFM rating of 2000 minimum to do the job and around 3000 CFM if towing a lot offroad to replace the mechanical one along with the standard electric one. Generally this means a fan of at least the same size ( 15" ) as the one it is replacing or bigger but there are some 14" ones out there that pull these CFM numbers.
http://jeep-xj.info/HowtoTaurusFanInstall1.htm
ninjakid is offline
post #628 of 3708 Old 08-30-2013, 10:10 AM
Newtons3
Newtons3's Avatar
JIm
In a racing situation, especially carbureted with low fuel pressure, you will want cool fuel. My proposals are for economy only. These ideas are not new nor original. They are based on work done by our predecessors like Smokey Yunick. On your Jeep, I think you are working on a symptom rather than the solution. I have ovecome that problem several times and have never used the insulators. I started with a Raytech gun and logged the obscene temps on my 06 and went from there. On mine, the upper cats were causing way too much heat to be retained in the head. On this project, I intend to raise fuel pressure and use my premium injectors to control the problem. I dont think Ill actually be raising the rail temp of the fuel more than 25-30 degrees, ultimately. Really, Ill be stabilizing the temp across the operating range. My hope is that the pressure drop combined with the heat will lead to almost vaporization of the fuel or at least a really finely atomized mix. This coupled with a hot-air intake should net me a couple of mpg. We will see. Im attempting to try it on something other than a Cherokee first.
Newtons3 is offline
post #629 of 3708 Old 08-30-2013, 10:26 AM
Newtons3
Newtons3's Avatar
Ive also been told by several sources that 3000 to 3600 is needed. I have disputed the claimed 3000ish cfm factory fan claim for years. In stock trim, pulling through half the radiator and condenser, with the crappy shroud, and with the hood closed -in other words, in the real world- I dont think it reaches that efficiency. Ive had real success with 3, 900-1200 cfm fans or either the factory aux fan and one 2000-2400 cfm fan when they are all shrouded properly. The key to our success has been venting the hood, usually with louvers.
Newtons3 is offline
post #630 of 3708 Old 08-30-2013, 10:52 AM
tamnoz
fuel
Newtons3,
Thanks, you answered my next question about the louvered hood. So how do I keep from having my #3#4 injectors from crapping out? So do I understand that what your trying to accomplish is higher engine temps without higher under hood temps? I just gave my 16 yo daughter my 00 XJ which was parked for the last year and a half and she's only getting 12.9 mpg around town. I need to get it up to at least 15-16. Also I gave my local Jeep dealer that 0280155789 # for the injectors and they said it's not a good #.
Thanks Jim
tamnoz is offline
