My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs - Page 34 - JeepForum.com
 10Likes
post #496 of 3707 Old 08-21-2013, 12:53 PM
Newtons3
Newtons3's Avatar
Originally Posted by 1997xj View Post
I'm only going to run 335/70s
Those are at least 33s and maybe 36s depending on rim size and 13 inches wide. Quite a tire.
Newtons3 is online now
post #497 of 3707 Old 08-21-2013, 12:56 PM
Newtons3
Newtons3's Avatar
Thanks newtons3. One less project ;-)
Yeah. But one more for me.
post #498 of 3707 Old 08-21-2013, 01:49 PM Thread Starter
Charley3
Even though I can't have manual hubs for my situation, I do know some about the topic.
Warn makes a 5 on 4.5 hub conversion kit forJeeps, Ford Rangers and Explorers. It is relatively affordable and reliable.
I think it has more than enough strength for 31s, which is what it was designed for. Plenty adequate strength for 33s.
I think 35s are pushing its limits, but there are many TJ guys at this forum using it with 35" tires for rock crawling.
For a Ford Ranger or Exploder, I think it works with stock wheels.
I don't think it works with stock Jeep 5 on 4.5 wheels, but it might. I'm not sure. It'd be great if it did.
You could get some used Ford Ranger/Exploder wheels and they will fit an XJ, TJ, YJ and so that might also fit the hub kit. So that might be a way to get compatible wheels cheap.
Where this mod gets prohibitively expensive is if you buy new aftermarket wheels. IMO
If I wasn't handicapped, I'd probably want this mod.
The TJ guys are well familiar with this topic. Some YJ and XJ guys too.
To learn more, I suggest Googling "Warn 4.5 hub conversion", or start a thread in TJ section of Jeepforum.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #499 of 3707 Old 08-21-2013, 02:00 PM Thread Starter
Charley3
Goodbye gas mileage, acceleration, and braking.
Hello parts breakage.
Hello poverty.
Charley3 is offline
post #500 of 3707 Old 08-21-2013, 02:03 PM
Newtons3
Newtons3's Avatar
THE Warn does not accept stock Jeep wheels. 31s are ok. There are many reports of 33s being too much. This is one of the weaker kits.
post #501 of 3707 Old 08-21-2013, 03:09 PM
1997xj
1997 XJ Cherokee
It's just a 235 with a fat finger conversion
1997xj is offline
post #502 of 3707 Old 08-21-2013, 04:13 PM
Newtons3
Newtons3's Avatar
I have no idea what a fat finger conversion is. I do know that a 335 is 100 mm wider than a 235 and 140 mm taller. Nowhere near the same tire.
post #503 of 3707 Old 08-21-2013, 04:19 PM
Newtons3
Newtons3's Avatar
Has anyone considered heating the fuel, either before the fuel rail or at the injector?
post #504 of 3707 Old 08-21-2013, 04:32 PM
mschi772
1997 XJ Cherokee
I think "fat finger conversion" means typo (i.e. accidentally hit 3 instead of 2).
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #505 of 3707 Old 08-21-2013, 09:08 PM
Newtons3
Newtons3's Avatar
Got it. Now his post makes sense.
post #506 of 3707 Old 08-21-2013, 11:43 PM
1997xj
1997 XJ Cherokee
Yup. Sorry guys. I'm running 225/70s nokians now but going up to 235 duratracs this fall. Hopefully wont be too much rolling resistance
1997xj is offline
post #507 of 3707 Old 08-22-2013, 02:02 PM Thread Starter
Charley3
Weaker yes, but reputedly plenty strong for 31s, and reputedly easier to install than other kits.
Since 31s are the largest tire I'd ever want in future, this kit would look attractive to me, if I wanted manual hubs.
That said, do you know of other kits as easy and cheap to install that are stronger? If so, please list them. It would becuseful info for the thread.
Charley3 is offline
post #508 of 3707 Old 08-22-2013, 02:04 PM
bobthecatkiller
http://jeep-xj.info/HowtoMAPsensor.htm
how about this you can manually lean out your a/f ratio
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #509 of 3707 Old 08-22-2013, 02:05 PM Thread Starter
Charley3
I think that might be a good idea, if it wouldn't cause vapor lock.
I have heard of hypermilers experimenting with this. If it would help, it'd probably be most helpful in a cold Winter climate. I doubt it'd help in a hot climate.
Charley3 is offline
post #510 of 3707 Old 08-22-2013, 02:11 PM Thread Starter
Charley3
Interesting, but it says you can only fine tune mixture from 80 to 100% throttle. So sounds like more of a power tune than an economod, IMO.
From what I read, this is mostly done to fine tune strokers.
Charley3 is offline
