My front and rear bumper w/tire carrier build pics
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
I thought i would share a couple small projects that I've been working to finish before school starts again..
Rear bumper with swing out tire carrier For the rear bumper i wanted something a little different then the typical square tube bumper, i went for something with some more lines and contour. I'm pretty happy with how it came out.. Started out by opening up the rear cross member for my square tube mounts, which i added a piece of 3/8 flat to the inside and drilled and tapped 1/2in holes. I could have just done a nut strip but i went this route.. I also added the ears to use the stock mounting holes as well. Ended up with a total of 14 bolts holding it on. ![]() ![]() The main section of the center of the bumper is 2x4x3/16th.. provides a nice base structure for the hitch and a little easier to work off of then plate. ![]() ![]() Some gussets. receiver burned in ![]() ![]() Sides started, welded some flat on an angle to the bottom to give it a nice contour. ![]() ![]() top skin tacked in ![]() swing out tire carrier spindle welded in.. this is basically a weld on trailer axle spindle.. I was going to put together my own but i ended up ordering it from A to Z fab, seems to be more cost effective. ![]() Side wrap around started.. ![]() side wrap around finished and tire carrier started ![]() ![]() carrier ready to be welded up, minus mounting plate. ![]() ground down and mostly finished off, ready for paint. ![]() Painted and mounted up.. ![]() ![]() I braced these side pieces with some square stock into the spring mounts to stiffen it up for side hits. You cant see it in this picture, but this one gives you a good view of the wrap arounds and the latch. ![]() ![]() with the winch.. ![]() Il post pics up of the front tomorrow morning..
#2 |
that looks tight!
#3 |
That is a nice looking bumper you made. Very classy and looks strong as a Sherman tank.
2000 Jeep Cherokee Sport. |
#4 | ||
I hope to never rear-end you. Nice bumper. Welds are pretty too.
#5 |
excellent work man! that thing a gorgeous.
nothing to see here. |
#6 |
that bumper is beautiful
Give all your worries to the lord and he will comfort you |
#7 |
Very nice.
2010 Jeep Wrangler Sport Automatic/Hardtop/2-Door Cherokee Roof Rack Kenco Roof Basket |
#8 |
The Great White Ghost
Damnit, why do all the people that do such nice work like this live so damned far away from me???
I'd keep you stocked in your drink of choice for several months if you made me one exactly like that!! But shipping would be the deal killer.
A big thank you to whomever sponsored my membership!! 1974 CJ-5 258 3spd SOA on 31's [Sold in 1991] 1995 ZJ Limited 5.2 on 31's [Sold in 2009] 1990 XJ Laredo 4.0, nothing special [Sold in 2010] 1955 Willys CJ-5 #12171 [Sold in 2011] 1997 ZJ Limited 5.2 The Great White Ghost 1953 Willys M100 trailer |
#9 |
DUDE... I like it... that is nice. I like how the tire fallows the lines of the rear window. Very Nice.
#10 |
Beautiful fabrication and attention to detail. You should market that in your area
99' XJ ~4.0L6~NP231~6" Hybrid RC lift~MT Classic Lock~Detours Custom Light Bar Brushguard~Detours TailBone~Hooker Aero~aFe stage2~KC slimlines~JKS ACOS~JKS Disco.~JKS track bar~JCR T.C.Skid~JCR Stage 3 sliders~JK bumper fogs |
#11 |
Very Nice!
98 Cherokee Sport- 4.5", AA SYE and TW Shaft, 33" Cooper Discoverer STTs, XCr8000, Jcroffroad Stage 2 Winch Bumper , 60" Hi-lift, Cobra Ultra III, Gragar Soft 8s, Detour Tail Bone, jcr Offroad Stage 2 Sliders, RockCrusher Diff Covers Front, Lockright in the front, Aussie in the Rear (Ford 8.8) with 488s... More $$$ for Bank Account (On Back Order...) 99 Cherokee Sport- Stock and Staying that Way (Wife's DD) Christian Jeep Group Member #160 |
#12 |
great design and fine work!!
Chuck formerly known as "cwagoner" "Things will remain the same until they change" 1995 YJ Wrangler 1989 F350 |
#13 |
" Volkswagen "
That is a very nice bumper! Great looking, and beautiful welds too.
Jeep build up...ONGOING Jeep build up...ONGOING R.I.P. Tow Pig Dually build Rear bumper/spare tire carrier build Track bar bracket fabrication AtoZ cage install/build NeetoCJ was a generous guy and renewed my membership..... Blame him for your troubles! |
#14 |
Thanks guys!
On to the front.. I wanted the front to match the rear, just basically keep the same design and lines and make it work with a front bumper. As it started to come together I realized it started to look similar to the rigidco bumper, which is really nice looking so i just went with it. The overall construction i did the same way as the rear for the most part.. Mounts: ![]() ![]() center tube, receiver and gussets ![]() ![]() Sides started.. ![]() Mostly done, gusset detail. After this i added a brace from the mounts out to the side wings to ensure that they cant move. ![]() Ground down, finished off and primed ![]() ![]() Painted and mounted.. ![]() ![]() ![]() ![]() |
#15 |
very nice job on both front and rear bumpers, im inlove with the rear one tho rlly like your design
98 Cherokee Sport, |6 4.0, custom coldair intake, Poweraid TB spacer, 235/75/15's dunlop radial rover a/t, cobra Cb, cherrybomb turbo exhaust, E3 performance spark plugs, hood scoop,2 Hella 700ff, 4 Navigator NV-331 mounted to custom lightbar, smoked out tail lights, alpine indash dvd, jl audio 10" sub. Lift coming soon. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
