Is my cherokee running warm? - Page 3 - JeepForum.com
post #31 of 35 Old 07-03-2013, 01:58 PM Thread Starter
Jeeper_YJ
Originally Posted by TheRealKTrain View Post
Hood vents are to help dissipate the heat being trapped under the hood, also known as heatsoak. IT WILL NOT REDUCE THE OPERATING TEMP OF THE MOTOR. That's a very common misconception around here.
Heat soak is when a motor reaches a certain temp and can no longer bring the temp back down?
I think my issue of "heat" is from header. Although, I think coolant temp is better now (with 3 row radiator) post #25. I would really like the hood temps brought down. That hood gets HOT!
'97 Cherokee, 99+ intake, 62mm TB, 703 injectors (new), k&n intake, Hypertech III, 180* stat (1/8" drilled hole), 2.5" manifold 2 tail pipe (Hooker Maxflow & hi flow cat), Perf header, 4.5" zone lift, 32" GY Dura Trac, Rear head rests. Comp cam "231" & Perf head (LS1 BIG valves 2.02/1.62). 3 row alum radiator.
Jeeper_YJ is offline
post #32 of 35 Old 07-03-2013, 02:03 PM
TheRealKTrain
JK Wrangler
http://www.oman4x4.com/hoodvents.htm
Well documented test.
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #33 of 35 Old 07-03-2013, 02:11 PM Thread Starter
Jeeper_YJ
Great link! Interesting the heat is more by the firewall. Probably from motor fan pushing it.
post #34 of 35 Old 07-03-2013, 03:57 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Hood vents do make a slight reduction in engine operating temperatures. The effect is most noticeable in stop-n-go traffic, and on the 4x4 trails, but also can be observed on the highway. I saw about a 5-8* drop in "normal" operating temps after I installed my hood vents.
The biggest misconception, is that hood vents can compensate for a weak or neglected cooling system. Regular routine maintenance is the only way to avoid overheating issues.
CJ7-Tim is offline
post #35 of 35 Old 07-03-2013, 04:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by CJ7-Tim View Post
Scan Tools and OBD-II data readers are said to display temperature readings that are 10* less than what is indicated on the dashboard gage.
Since older XJ's have 2 temp sensors in different locations, a wider variation in temp readings would not surprise me.
195*-210* is normal for the 4.0L, and seeing 215-220* under extreme conditions is also normal.
I think the temp gauge on the 88 is inaccurate. Same scan tool on the 90 MJ shows straight up the gauge while 195 on the tool.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
