Is my cherokee running warm? - JeepForum.com
post #1 of 35 Old 06-27-2013, 08:36 PM Thread Starter
Jeeper_YJ
Today was 100* outside. No stop and go. Around town. Ran at the notch above 210* on gauge (220*?). I did have buddy shoot a heat temp laser and the gauge is accurate. I have replaced last month:
Fan clutch (heavy duty)
Aluminum 2 row radiator
New hoses
New water pump
180* t-stat
coolant sensor
Radiator cap
Synthetic oil change
I did also just did a comp cam and performance head swap along with a performance header. Do hood vents actually work? Anyone done it and can verify?
'97 Cherokee, 99+ intake, 62mm TB, 703 injectors (new), k&n intake, Hypertech III, 180* stat (1/8" drilled hole), 2.5" manifold 2 tail pipe (Hooker Maxflow & hi flow cat), Perf header, 4.5" zone lift, 32" GY Dura Trac, Rear head rests. Comp cam "231" & Perf head (LS1 BIG valves 2.02/1.62). 3 row alum radiator.
Jeeper_YJ is offline
post #2 of 35 Old 06-27-2013, 10:39 PM
Craig00XJ
I read over and over on this site that you should use a 195 degree thermostat. Maybe try that first? Certainly a cheap fix if it turns out to be the cause.
Craig00XJ is offline
post #3 of 35 Old 06-27-2013, 10:41 PM Thread Starter
Jeeper_YJ
Ran both, same result.
Are you saying it is running hot?
post #4 of 35 Old 06-27-2013, 10:43 PM
Craig00XJ
Yeah, it should be around the 210 mark
post #5 of 35 Old 06-27-2013, 10:46 PM Thread Starter
Jeeper_YJ
100* outside, and A/C on? Ok.
What else can I replace? I'm at a loss.
post #6 of 35 Old 06-27-2013, 10:55 PM
Puck81
That is where my XJ likes to run in our heat. You are good bud. And yes hood vents are a good thing out here too. Btw what side of town you on?
Puck81 is offline
post #7 of 35 Old 06-27-2013, 10:57 PM Thread Starter
Jeeper_YJ
Henderson.
The notch passed 210* is 215 or 225*?
post #8 of 35 Old 06-27-2013, 11:14 PM
Puck81
It's ~220ish. The factory electric fan comes on at about 209 and shuts off at about 220, and that is about the mark mine shuts down. I live close to Henderson, off of Windmill pkwy and the 215. You should visit the Vegas thread some time.
Puck81 is offline
post #9 of 35 Old 06-27-2013, 11:17 PM Thread Starter
Jeeper_YJ
You mean on at 218 and off at 209? Is this normal running at 220* or so you think the radiator I put in is maybe clogged or bad?
post #10 of 35 Old 06-27-2013, 11:26 PM Thread Starter
Jeeper_YJ
Is it possible the new radiator is clogged or bad?
post #11 of 35 Old 06-27-2013, 11:44 PM
Puck81
There you go, sorry i am a tad tired.
Puck81 is offline
post #12 of 35 Old 06-27-2013, 11:45 PM
Puck81
I dont think so. XJs will never run cooler then 210-220. Its how our motors are tuned to run.
Puck81 is offline
post #13 of 35 Old 06-27-2013, 11:50 PM
sAe23
1995 XJ Cherokee
My 95 runs right around 210* (A/C ON) on a normal SoCal day.
When it gets above 95 - 100 degrees, the gauge gets real close to the 3rd mark, which I guesstimate is 235*.
Turning the A/C off and/or turning on the heater for a few minutes usually brings it back down.
Yours sounds ...typical...
sAe23 is offline
post #14 of 35 Old 06-28-2013, 06:08 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
220 is fine and normal for hot days.Mine runs the same.
TheBoogieman is offline
post #15 of 35 Old 06-28-2013, 07:07 AM
tim111762
Down here in the Florida heat I run 210-220 range normally
tim111762 is offline
