-   -   Is my cherokee running warm? (http://www.jeepforum.com/forum/f11/my-cherokee-running-warm-1542251/)
Jeeper_YJ 06-27-2013 09:36 PM
Today was 100* outside. No stop and go. Around town. Ran at the notch above 210* on gauge (220*?). I did have buddy shoot a heat temp laser and the gauge is accurate. I have replaced last month:
Fan clutch (heavy duty)
Aluminum 2 row radiator
New hoses
New water pump
180* t-stat
coolant sensor
Radiator cap
Synthetic oil change
I did also just did a comp cam and performance head swap along with a performance header. Do hood vents actually work? Anyone done it and can verify?
Craig00XJ 06-27-2013 11:39 PM
I read over and over on this site that you should use a 195 degree thermostat. Maybe try that first? Certainly a cheap fix if it turns out to be the cause.
Jeeper_YJ 06-27-2013 11:41 PM
Ran both, same result. :(
Are you saying it is running hot?
Craig00XJ 06-27-2013 11:43 PM
Yeah, it should be around the 210 mark
Jeeper_YJ 06-27-2013 11:46 PM
100* outside, and A/C on? Ok.
What else can I replace? I'm at a loss.
Puck81 06-27-2013 11:55 PM
That is where my XJ likes to run in our heat. You are good bud. And yes hood vents are a good thing out here too. Btw what side of town you on?
Jeeper_YJ 06-27-2013 11:57 PM
Henderson. :)
The notch passed 210* is 215 or 225*?
Puck81 06-28-2013 12:14 AM
It's ~220ish. The factory electric fan comes on at about 209 and shuts off at about 220, and that is about the mark mine shuts down. I live close to Henderson, off of Windmill pkwy and the 215. You should visit the Vegas thread some time.
Jeeper_YJ 06-28-2013 12:17 AM
You mean on at 218 and off at 209? :) Is this normal running at 220* or so you think the radiator I put in is maybe clogged or bad?
Jeeper_YJ 06-28-2013 12:26 AM
Is it possible the new radiator is clogged or bad?
Puck81 06-28-2013 12:44 AM
There you go, sorry i am a tad tired.
Puck81 06-28-2013 12:45 AM
I dont think so. XJs will never run cooler then 210-220. Its how our motors are tuned to run.
sAe23 06-28-2013 12:50 AM
My 95 runs right around 210* (A/C ON) on a normal SoCal day.
When it gets above 95 - 100 degrees, the gauge gets real close to the 3rd mark, which I guesstimate is 235*.
Turning the A/C off and/or turning on the heater for a few minutes usually brings it back down.
Yours sounds ...typical... :D
TheBoogieman 06-28-2013 07:08 AM
220 is fine and normal for hot days.Mine runs the same.
tim111762 06-28-2013 08:07 AM
Down here in the Florida heat I run 210-220 range normally
The time now is 05:56 PM.
