Quantcast My A/C just got worse need help? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > My A/C just got worse need help?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 06-02-2007, 09:14 PM   #1
turkish6
I am horrible at describing problems but I hope I make it clear.
ok so hear we go.
For about a month we have been having A/C problems. It would blow cold air on the highway and just regular air around town. I refilled the gas and it was fixed. about a week after that it started to do the same thing. around the same problem in the mornings when we start the jeep it make a high pitches squeel (hope thats spelled right) and the squeel would get more and more high pitched by the second and after about 4-5 seconds it would stop and everything would be fine. it has been doing this the past few days. everything seems looked and ran fine besides the a/c. tonite we went out to dinner. on the way there the a/c stopped blowing cold air and blew just regular air on the highway which it never did. anyway after dinner we get into the car and I start the truck and it starts to the high pitched sound but this time it did not stop and it started to smoke. I shut her down open the hood. it smells like burning rubber. so as I am watching I have the wife start the jeep. same thing. the main belt isnt spinning. the lower wheel coming from the engine is turning but the belt isn't moving. also i can't turn my steering wheel. my question is..... is my power steering seized, is my a/c seized (cause thats the problem I have been having) or is it something else. Obviously i couldn't drive it home. I will go in the morning in daylight and investigate more. But what should I do.... I need all the help I can get.
edit. the belt is really tight and i can't turn the a/c wheel or the power steering wheel by hand
turkish6 is offline   Reply With Quote
Old 06-02-2007, 09:21 PM   #2
Atari.fan3000
It sounds like you have one (or multiple) bad bearings in your acc.'s or engine block....also how old is the belt and was it over tightened? an overly tight belt will burn out bearings fast.
98 XJ SE 4.0 L White 70,xxx miles RE 3.5in Super Flex Lift, BFG AT 32x11.5x15; adj Control arm, RE gen2 disco's, T-case drop
Factory Front Skid/ TC Skid/ Gas Skid; Cobra 18 WX ST II SoundTracker CB 3 FT firestick mounted on RoofRack;
Set of BaJa lights top bumper mounted; Light bar/w 150watt KC DayLighters ;Rusty's Air intake; FM Delta 50
C 4X4 front tow hooks; Rear Hatch Speakers; Painted Fenders Flares; herculined floor; Back-Up lights inside bumper
My car Domain Page
Atari.fan3000 is offline   Reply With Quote
Old 06-02-2007, 09:26 PM   #3
turkish6
the truck is a 2000. i bought it used year and a half ago. as far as service records go it seems as though it has never been changed. i have never gotten it tightened. it has 85000 miles on it. and the engine itself seems to run perfect.
Old 06-02-2007, 09:35 PM   #4
Atari.fan3000
well if you had 85k on the clock, it should have probability been replaced a few thousand miles ago. How does the belt look does it have cracks? in it how worn does it look. Any way it sounds like you are going to need a new belt any way. as for checking the bearings I have never had to do that so maybe someone else will chime in and help you with that
My car Domain Page
Old 06-02-2007, 09:39 PM   #5
turkish6
the belt looks good. no cracks etc. how can I loosen the belt? to see if it helps.
Old 06-02-2007, 10:35 PM   #6
TPI Monte SS
Turn the AC selector to OFF, and then try starting the truck. The smoking and high-pitched squeals mean that the belt was slipping over a locked-up accessory. I'd bet, based on the symptoms you mentioned, that the AC compressor has siezed.
Steve Ragusa - North Jersey
'01 XJ - SOLD!
'06 Infiniti G35x - New DD. :)
'03 KJ Limited -WifesJeep- 3.7, Auto, NP 242, '06 Limited 17's. 40K miles.
TPI Monte SS is offline   Reply With Quote
Old 06-02-2007, 10:59 PM   #7
turkish6
the a/c was on off. and the belt is not turning at all. the the wheel coming from the engine.
Old 06-02-2007, 11:14 PM   #8
turkish6
also. lets say it is the a/c. is it the compressor? is it the fan assembly? is it the condenser. what is actual part that would need replacing.
Old 06-02-2007, 11:53 PM   #9
TPI Monte SS
It would be the compressor; that's bolted to the top of engine brackets on the passenger side. If you loosen the tension on the belt and slip it off, you could at least start the truck and drive it onto a flatbed. You really can't run it far, since it the alternator won't charge with the belt disconnected.
'01 XJ - SOLD!
Old 06-03-2007, 12:08 AM   #10
scorpio18
You could go to a local salvage yard and pick up a used a/c compressor for your jeep, and even if it doesn't work you could still use your car....good luck
http://www.car-part.com/
scorpio18 is offline   Reply With Quote
Old 06-03-2007, 12:37 AM   #11
turkish6
i looked at car-part already. i just want to make sure it defiantly is the compressor. how would i loosen the belt enough to get it off the compressor.
Old 06-03-2007, 09:52 AM   #12
Goldenknob
1992 XJ Cherokee
On my jeep there is a tensioner screw on the under side of the power steering pump.
Goldenknob is offline   Reply With Quote
Old 06-03-2007, 07:37 PM   #13
AZ Jeff
ON a 2000 model year, the serpentine belt is tensioned by a moveable idler pulley located under the PS pump. To adjust the idler, FIRST loosen the center bolt on the pulley about 1 full turn. Then, located between the PS pump and the thermostat housing is a bolt that is tipped at a 45 degree angle towards the thermostat. Tightening that adjuster bolt moves the idler to tighten the belt.
Based on your description, I would say your compressor is having problems, but the question is "WHY?". You say, in your first paragraph "I refilled the gas". I assume this means you added refrigerant, but how did you MEASURE how much you added? If you overfill the system, you can hydrolock the compressor and trash it.
Once you verify the compressor is defective, and obtain a replacement compressor, you will need the system evacuated and refilled by someone with a AC manifold and a vacuum pump, if you don't have those items.
Good luck.....
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 06-03-2007, 08:29 PM   #14
hennigm4
My bet would be the ac compressor has seized, at this point it will make no differece if ac is off or on, had this happen to me on a chevy astro.
What I would do now is remove serpentine belt and find one that will work if you bypass the compressor, and old trick is to take a string and run it around all the accessories that you still need to run, just don't put it around the compressor pulley, measure the length of the string then go off to the auto parts store.
The other option is a new compressor, a little more expensive, since you said the ac stopped working that could be the problem. As far as the power steering, isnt it hard to turn with fluid in the system?? Not sure but if it still has oil I doubt that would be seized, could be though.
hennigm4 is offline   Reply With Quote
Old 06-03-2007, 08:35 PM   #15
BrunoS
seized a/c compressor, plus the compressor clutch has fused with the pulley and won't release.
if you are lucky, you can turn the seized a/c "off" and then the magnetic clutch pulley will relase. you said that it was still stuck.
try to pry a screwdriver to get the compressor clutch pulley disengaged, and then disconnect the power quick connect going to the back of the compressor.
if you can get the clutch unstuck, then you can drive around forever on the belt no problem.
you can also bleed the refrigerant down and perhaps the compressor will start turning again, usually a relief valve blows or a hose pops first.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Glock Forum
