My ACTUAL Evaporator/Heater Core Removal/Installation Thread.....
#16 | |
Awesome write-up!
This will definitely make the replacment ALOT easier for everyone who needs to do the job. This is the best write-up I've seen. It certainly would have helped me when I did mine about 6 weeks ago. I didn't end up dissassembling quite as much stuff as you did, but I definitey see how getting it all "out of the way" made the removal of the HVAC box easier.
http://www.mrrebates.com?refid=413556 - As seen on CNN, New York Times, etc. Earn $5 and receive cashback from nearly all online stores (+ 3% back on all ebay purchases). - Better than EBATES. 98 Cherokee, SE (195,000 miles) 4.0 Automatic, 4X4 Part-Time System (Jeep is entirely stock! No mods.) |
#17 | |
I'm hoping to get started again on it tomorrow morning if I get a chance and hopefully it'll be done by tomorrow night....then no more dash removal for me.....EVER
[SIZE="1"][CENTER]'98 XJ Sport, 4.0L, AW4, NP231, HP30/8.25" 3.5" RE Superflex, Full Leafs, OME's All Around, JKS Trackbar 31x10.5R15 Mickey Thompson Baja MTZ's on 15x8 Rockcrawler's (3.75" BS) C4x4 Front Tow Hooks/Rear Hidden Hitch[/CENTER][/SIZE] |
#18 |
Awesome writeup. I'm dreading when mine finally goes (as I'm suuuure it will).
As for the heater core leak: remove and re-seat the heater hoses on the bungs that protrude from the firewall, and TIGHTEN the screw-clamps. I replaced a core in my old YJ for no reason because of this! Granted, a YJ core is alot easier, but I had no clue what I was doing, and this was pre-internet/JU/JF/whatever (~1995).
stale milk white 97 Police Package XJ (former FD gofer vehicle) bought in 11/08 w/ 41.6k**95 YJ 4cyl/5spd summer beater ************************************* Past Jeeps:97 XJ Sport 6cyl/auto, 00 TJ 6cyl/auto,95 YJ 4cyl/5spd 95 XJ SE 6cyl/auto, 93 YJ 4cyl/5spd |
#19 |
ZOMFG this looks like a royal PITA. I'd just assume drive around with no heat than go through all that garbage. What a crock...
**2008 Jeep Patriot Limited 4x4** 60k, *Absolute Rubish* Former- 2004 Jeep Grand Cherokee Special Edition 4x4 V8. 1999 Jeep Cherokee SE |
#20 | |
I have been in that position (due to a PLUGGED heater core), and let me tell you, it's NO fun. Living without AC is feasible. Living without heat (in the northern 2/3 of the US) is pretty much impossible in the winter.
AZ-Jeff 1992 XJ 2" lift -- RIP 2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links. |
#21 |
thanks so much for a great write up and for so many helpful pics. I just started tearing apart my XJ today to replace the heater core, but at the advice of the commerical parts supply house, I'll also be replacing the evap core at the same time. After seeing the pics, it looks like the blower motor is only accessable when the HVAC box is out, so I'll replace that part as well.
I don't have a FSM, so my plan was to just use my VW experience and just figure things out as I go along. ( VW's from 1993 to present also require the full dash to be removed for heater core replacement). I wouldn't have thought about removing the seats, but now I see what a good idea it is. I hope other people will find your write up as useful as I have. |
#22 |
Does the whole dash need to come out for pre 97's? That is one crazy design. I can see now why I've heard shops quoting upwards of 1000 bucks for this job.
#23 |
Why did you change the accumulator? Was there something wrong with it, should it be changed for some reason? And lastly if you change both you said to put in 6 oz total of oil? My A/C leak too and they say it's the Evap. but I have yet to work up the will/care/decide to start doing something about it.
#24 |
The blower motor can come out/be changed without having to do any of the dash removal or anything. The accumulator was replaced just because. I had the system open to the elements for about a week so the dessicant bag in the accumulator was probly shot anyway.
#25 | |
#26 |
I'm convinced my A/C hates me.....after all that this summer, I finally got the heater core changed back out and everything buttoned back up, A/C charged and boy did it ever blow nice and cold.....for about three days then my condenser packed it in......back to square 1....I left it though cuz it was September and I couldn't justify spending MORE money on A/C at that time of year.....it'll wait until the spring
#27 |
Unfortunately this is way out of my league. My regular Jeep mech doesn't even do them, takes them to a referral shop.
What would be a fair price to pay? I'm in Denver. Trying a flush with additives and refill but not holding out too much hope. 130,000 miles 2001 Jeep Cherokee Sport 4 liter. Blows cold air until about 30 minutes go by then luke warm on low setting. Enough to keep it above freezing for now, but planning ahead, don't know if I'll make it through Winter. Storm chasing skier to make matters worse. Thanks |
#28 |
fyi, I had good luck with the solvent. Let it run for 150 miles over 3 days. Backflushed the heater core from both sides. Large difference before and after, both in temperature of the hoses and the air in the cabin. Absolutely recommend it for anyone who has a slowly clogging core.
I don't expect it to last forever though, hope it gets me through the Winter. So still curious what a fair price is. |
#29 |
I'd like to know the answer to this one as well. Does anyone know? I'm in the market for an XJ, and if the 96 and earlier were easier to put a heater core in, it may influence my decision.....
In the market for an XJ..... got one for sale? |
#30 |
The Pre-97 heater core R&R procedure is pretty much the same as that for the later models.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
