Quantcast My 95 XJ build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > My 95 XJ build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 06-01-2008, 08:20 PM   #1
gijazbo
My 95 XJ build
well i just graduated high school and i don't really have tons of cash to spend so this build will be a slow one. i got my rig from my grndfather with only
85K miles on it.... yeah a 95 with 85K. However, i'm in Ohio and salt took its toll. so heres what i've done so far.
- coated the underside
-wall mart light bar
One of the fist things was a simple one,
- my CB stetup with PA
- and in the end this is what it looks like until i start to tear it apart
- next its an the RC 4.5" lift kit with full pack
-quick disco's
-new track bar
-set of 31" BFG AT's
-Front hitch
-rear hitch
-snorkel
-skid plates
gijazbo is offline   Reply With Quote
Old 06-01-2008, 08:21 PM   #2
gijazbo
almost forgot
I also repaited the trim with Krylon.... i like it.
Old 06-01-2008, 08:22 PM   #3
Wearingthin
*something clever*
Wearingthin's Avatar
Originally Posted by gijazbo View Post
well i just graduated high school and i dont really have tons of cash to spend so this build will be a slow one. i got my rig from my grndfather with only
85K miles on it.... yeah a 95 whith 85K. However, im in ohio and salt took its toll. so heres what i've done so far.
- underlined the underside
- herculined the interior ( people always ask why i put the carpet back in afterward .... answer it sounds like a BMW now.
[IMG][/IMG]
- custom gijazbo(aka homemade)front brush guard with lights and clevis mounts.
[IMG][/IMG]
... i think the welds werent too bad for my first time welding...
[IMG][/IMG]
- these are the measurments if anyone wants them?
[IMG][/IMG]
- new sound system ( A must for all teenagers ya know...ha)
[IMG][/IMG]
[IMG][/IMG]
- Repainted the stock rims
[IMG][/IMG]
- my CB stetup with PA[IMG][/IMG]
- and in the end this is what it looks like....
[IMG][/IMG]
-quick disco's
-new track bar
-Front hitch
-rear hitch
-snorkel
-skid plates
..... as for now thats all but more to come guys .... whoevr can make this a no clicky your awesome.
no clicky
1234567890
Wearingthin is offline   Reply With Quote
Old 06-01-2008, 08:30 PM   #4
gijazbo
Thanks WEARINGTHIN.
Old 06-01-2008, 08:37 PM   #5
camjeep3
1988 MJ Comanche
i'm not to sure about those shackles, how are they tied in? But so far it looks good keep it up!
2011 Chevy Silverado ext cab z71
1988 JEEP Comanche 4x4 shortbed:
4.0L w/ 5spd
6inch RE lift w/ Spring over-8.8 aussie locker and 4.56s
High School Jeepers #15
camjeep3 is offline   Reply With Quote
Old 06-01-2008, 08:46 PM   #6
Mr_Random
1986 XJ Cherokee
WOW... way nicer than mine, congrats on graduating! (I just did too!) I'm so happy, time to start working alot, making money for my jeep and college!
I wouldn't go with the full 4.5" YET or at all, if you don't have much cash, because it'll suck more money than you expect (think DS's, SYE, LA/Adjustable CA's).
You can do a DIY/Homebrew/JY lift similar to mine for MUCH cheaper and still get about 3", which can easily accommodate 31's and still look good (and get you moving faster on your other plans).
Look on here for 3" lift coils, 3" shocks, and go to your local JY's in search of s10 leaves, and that'll be about good for what ya need (and you can aim as low as $150 if lucky).
That was a nice, pretty weld, I expect you practiced on scraps before hand? I need to learn how to weld... maybe I'll pull out my dad's machine right now...
Anyways, looks nice and clean, and perfect for a post-high-school student!
Oh, and unless you want to rip off that PA the next/first time you wheel, relocate it into the engine compartment!
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
http://www.jeepforum.com/forum/f22/86-xj-w-mpi-budget-re-build-757079/
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline   Reply With Quote
Old 06-01-2008, 08:50 PM   #7
tdogg55555
never seen a cb mounted there before, does that ever get in the way?
96 Country...Weekend warrior
tdogg55555 is offline   Reply With Quote
Old 06-01-2008, 09:03 PM   #8
Mr_Random
1986 XJ Cherokee
Actually looks convenient, but it looks like he has an auto, so unless he kicks it off getting in, I doubt it's much of an obstacle...
Jeepus buildicus:
http://www.jeepforum.com/forum/showthread.php?t=757079
Old 06-01-2008, 09:57 PM   #9
gijazbo
Nothe CB is no problem when getting out. Really convinient too. As for the front shackles on the brush guard i just had them laying around and threw them on.......not functional other than pulling a lawnmower or a fat kid.... and as for the lift i planned on it i should have like 900$ in like 4 weeks from my job so i will have the lift and other things like a hac n' tap spacers, brake lines, as for the LCA's the kit come with new ones.
Old 06-01-2008, 10:22 PM   #10
jshaab2
looks nice i like the brush gaurd its clean. and the subs in the back looks nice. how much those 2 subs run you.?$$
and get recovery
01 xj sport . SS headlights sound system . dakota AT's 235/75 sound system and front and rear recovery, CB . AUX lighting EXIT 105 NJ
jshaab2 is offline   Reply With Quote
Old 06-01-2008, 10:34 PM   #11
Veeb0rg
1995 XJ Cherokee
you might want to try flipping the radio mounting bracked over, it should center the radio in the dash hole better.
Veeb0rg is offline   Reply With Quote
Old 06-01-2008, 10:51 PM   #12
gijazbo
the s subs are Volfenhag 12" with a sony x-plod 1000W amp. Got it all on ebay 90$ for the subs and 100$ for the amp(refurb). The subs i got for a steal though (usually like 200 a piece)...check ebay though the gut i bought em form has a store. i will look for the name. As for the radio it works for now my i asked my dude at a local audio store about it and he says he always has problems with cherokees. all the buttons are easy to get to but the face plate cant come off.( i live in a good area though.... my security system is that i hope eventually people will look at my jeep and go " man i aint messin with that guys rig, he's probably a scary dude"... lol
Old 06-01-2008, 11:02 PM   #13
Veeb0rg
1995 XJ Cherokee
Yeah, my kit was like yours, cept the face on my radio drops down for cd access, so I had to do something, I found flipping the mount over sits the radio up higher.
Old 06-02-2008, 03:44 PM   #14
gijazbo
hey
Thanks i will give it a try.
Old 06-02-2008, 09:31 PM   #15
Tarukai
Aw man, nice build so far! I'm graduating in a few weeks (our school district sucks! we get out late June D=), and I'm going to probably take on a full-time job for the summer working as an order-picker in the warehouse where my dad works (SYSCO food services), and once that money makes its way to my bank account in the first month or so, I'll start re-vamping mine.
your welds look wicked clean, dude! very nice! I need to practice too, luckily my uncle left his welder here =D
Good luck with this build, man, and that idea for the diesel pipes sounds awesome. Also, that CB placement looks kinda weird to me, like you'd be catching your foot in the wire for the mic every time you try to get out, but iono =/
Tarukai is offline   Reply With Quote
Glock Forum
