My 4WD is making a grinding noise. Any ideas? - JeepForum.com
post #1 of 10 Old 12-05-2010, 10:37 PM Thread Starter
300zxnovaman
1997 XJ Cherokee
Hi, I noticed this grinding sound coming from the front part of my Cherokee after i put it into 4WD.
I have looked under the front end as much as i could with out removing anything. and everything looks fine. no rubbing of the drive shaft or tires. the CV joints look fine. I don't know what it could be. maybe it's something inside the front dif, or t-case? and this sound only happens when in 4WD. It also gets worse and effects the steering when i turn the wheel while moving forward.
Has anyone else had this problem?
Does anyone having any ideas what it could be, so i don't have to just start pulling my whole front end apart blindly.
Anything helps thanks.
300zxnovaman is offline
post #2 of 10 Old 12-05-2010, 11:11 PM
the_weirdo
the_weirdo's Avatar
See other thread - is this happening when you drive it on the street or when you drive it in the dirt? You should never use your 4wd when on the street. If you do, binding and weird noises are to be expected and are completely normal.
the_weirdo is offline
post #3 of 10 Old 12-05-2010, 11:19 PM
Jameslol
check the linkage mechanism bs under there, mine likes to pop out if i try to put it in 4lo and i will get trapped inbetween 4hi and N.
Also the weirdo is incorrect, you CAN drive it on the pavement, but not if its dry, Low traction situations like snow and ice ONLY and like gravel.
Black 1996 Jeep Cherokee Sport, 4.0, 4WD, NP231.
31 inch Yokohama Geolanders.
3" Rough Country AAL Kit. ZJ tierod.
C4x4 Front tow hooks.
Nates 4x4 rear bumper w/receiver and shackles
Iron rock offroad double shear adj trackbar
Jameslol is offline
post #4 of 10 Old 12-06-2010, 12:37 AM Thread Starter
300zxnovaman
1997 XJ Cherokee
Mine has got stuck to0. wouldn't go back into 2WD for a bit. finally got it out. now i notice the sound that we have been talking about.
post #5 of 10 Old 12-12-2010, 10:19 AM
resident67
1989 XJ Cherokee
i have the same problem and I went through the wheel joints mine sounds like its coming from the right side...
this is killing me....
resident67 is offline
post #6 of 10 Old 12-12-2010, 04:41 PM
AZ Jeff
2014 JK Wrangler
Start by jacking up the front end and spinning the wheels and drive shaft by hand. Listen for noises (other than brake drag), and narrow it down from there.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #7 of 10 Old 12-12-2010, 04:43 PM
04KJlimited
2004 KJ Liberty
CAD? center axle disconnect?
04KJlimited is offline
post #8 of 10 Old 12-12-2010, 05:23 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Check level of fluid in the t-case yet?
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #9 of 10 Old 12-13-2010, 02:38 AM Thread Starter
300zxnovaman
1997 XJ Cherokee
no i have been slammed with work.
i'll post something as soon as i know.
probably by this coming weekend.
post #10 of 10 Old 04-20-2011, 03:14 PM
mh31792
88 grinding
my jeep 88 cherokee is doing something similar. every time i give it to much gas from a dead stop i hear grinding coming from underneath. its just from a dead stop and only in the first gear and it again it only happens when i floor it or rev it to high then after it shifts up its fine. it started after i was testing out the 4x4 low. when i shifted down to low it wouldn't connect right and only really connected if i held the lever all the way back and drove for a bit. if anyone could give me some more information on it that would be great and i really hope its not the tranny. also the fluids are all at good levels i just checked them last night.
mh31792 is offline
4x4 , cherokee , dana 30 , grinding noise , t-case
A/C Making Grinding noise cricketo99 XJ Cherokee Technical Forum 7 06-25-2015 04:38 PM
ax-5 let go and started making a grinding noise. what does this mean? yepits2wd XJ Cherokee Technical Forum 2 06-24-2010 09:41 AM
Drivetrain noise - grinding and whooping noise (like curly from 3 stooges) kellen XJ Cherokee Technical Forum 1 03-06-2008 04:24 PM
It's talking to me again (New noise) Grinding noise when stopped (5-speed) Junker XJ Cherokee Technical Forum 7 11-03-2005 10:51 AM
Still making Grinding noise... Rabindranath68 XJ Cherokee Technical Forum 5 06-21-2004 02:42 PM
