My 1998 Jeep xj won't start - JeepForum.com
post #1 of 4 Old 09-02-2012, 03:42 AM Thread Starter
wheeliedealie
I've changed out the cap and rotor, found out my battery was bad so i changed that but still no help, shift it into natural and tried but no luck, tried jumping the starter with a screw driver that didn't work, its getting fuel to the engine so its not in the fuel system.. I am just lost.. It just cranks and cranks but it doesn't start.. HELP!
wheeliedealie is offline
post #2 of 4 Old 09-02-2012, 03:48 AM Thread Starter
wheeliedealie
I think it might be a sensor now but i don't even know what one to check.. I hear a lot about this damn crank sensor?
post #3 of 4 Old 09-02-2012, 07:00 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Fuel + spark (plus compression and air) = start.
You need to determine what part of the above equation you are missing. Do not assume anything and don't throw parts at this. It's terribly inefficient and expensive.
Pull a spark plug. Keep it attached to the plug wire. Place the spark plug electrode near a good engine ground. Have a buddy crank the engine over while you watch. You are looking for a strong, BLUE, snapping spark. Yellow/orange/white indicates a weak spark which may not be strong enough to start the engine. If you have no spark, then a crankshaft position sensor is a possibility. But so is the ignition coil and a few other things.
IF spark checks out okay (and only if), then try introducing a small splash of gasoline or a shot of starting fluid into the intake. If the engine runs for a few seconds with this technique, you have clearly identified a "fuel delivery" problem.
The above two things are easy to do and will help you ISOLATE the root cause of your problem. Start there.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 4 Old 09-03-2012, 11:40 PM Thread Starter
wheeliedealie
Yeah 99% sure its the crank sensor.. No spark, checked my coil with a meter and it checked out fine. So i'll find out tomorrow a buddy of mine works at a auto place so i can get the sensor for 56 bucks new which isn't so bad.
start problems
1998 XJ Won't start on 1st try, fires right up on 2nd attempt / slow start spenceuiuc XJ Cherokee Technical Forum 18 08-06-2012 07:26 AM
1998 Jeep Cherokee Classic wont start.. flipadelphia37 XJ Cherokee Technical Forum 3 03-26-2011 05:23 PM
1998 Jeep Cherokee Limited cranks but wont start Dottie XJ Cherokee Technical Forum 5 02-25-2010 02:57 PM
1998 won't start ckarlsso XJ Cherokee Technical Forum 1 08-12-2007 10:41 AM
1998 4.0 Hard to start hot steele4of12 XJ Cherokee Technical Forum 1 06-12-2004 09:40 PM
