mustang GT injectors - JeepForum.com
post #1 of 22 Old 09-01-2008, 07:20 AM Thread Starter
jimc_65
what year GT inujectors will fit my '89 cherokee 4.0L? Any modifications necessary with fuel rail or anything else?
jimc_65 is offline
post #2 of 22 Old 09-01-2008, 08:35 AM
HeepToJeep
1982 CJ8
Direct swap, no modifications needed.
Ford/Lincoln
1986 -1995 5.0 V8 Mustang
1996 -2004 4.6 Mustang
1997-1998 3.8 Mustang
1995-1996 Thunderbird
1997-2001 F-Series 5.0/5.8L EFI-MPI
1990-1992*5.8 E/F Series P/U Bronco
1997-2000 5.4 Expedition
1993-1996 4.0 Explorer
1998-2001 5.4 Navigator
1990-1992 4.0 Ranger
1996 4.0 Aerostar
1998 3.8 Windstar
1992-1998 4.6 Crown Victoria
1986-1990 5.0 Lincoln Towncar
1991-1996 4.6 Lincoln Towncar
GM
1990 Deville 4.5 V8
1991-95 Deville 4.9 V8
1985-88 Firebird TPI 305
1985-88 Camaro TPI 305
1994-96 Caprice 4.3 V8
Dodge
90-93 Trk/Van 5.2 5.9 V8
87-95 Dakota 3.9 V6
BMW
1996-98 840ci
1994-95 530i-3.0 V8
1991-94 318i, 318is
1985 318i 1766cc L-Jet
1988 325e
1988 528e
1985-87 635CSi
1985-93 535i
1985-92 735i
1988-92 735iL
1987 L6, L7
1992-98 740i, 740iL
1992-98 540i
Mazda
4.0 Navajo
Wm
HeepToJeep is offline
post #3 of 22 Old 09-01-2008, 09:44 AM
Dannn
what is the benefit of changing them? and will all of those fit a 98?
1998 TJ - 6.0 Vortec LQ4, 35's, Wheelies and Hurt Feelings Galore.
Dannn is offline
post #4 of 22 Old 09-01-2008, 09:46 AM
eflores
1989 XJ Cherokee
i have a set of the 318 5.2 dodge injectors....what is the difference in lbs or what ever its called
AEKDB
Leaky sunroofed XJ member #1
The United States of America July 4, 1776 - November 4, 2008 RIP
eflores is offline
post #5 of 22 Old 09-01-2008, 10:17 AM
Sublimize23
I know most stock GT injectors are 19#.
'98 XJ All stock
'02 Mustang GT - Toy
Sublimize23 is offline
post #6 of 22 Old 09-01-2008, 10:35 AM
Saudade
1988 XJ Cherokee
Check out Dino's site.
http://www.jeep4.0performance.4mg.com/tech_specs.html
The static flow rate must match unless you're running a stroker. The '98 needs a higher rated FI than the ones above.
As far as the Renix goes, the injectors offer a better spray pattern that can result in a better burn. I noticed an improvement in throttle response on my '88 but can't say I gained any noticeable HP. I got a set of 8 on eBay for about $50.
Saudade is offline
post #7 of 22 Old 09-01-2008, 11:46 AM Thread Starter
jimc_65
heep...i plan on installing a cold air intake too. I was going to buy 19lbs. mustang gt injectors. Will they give me significant HP and performance improvement? What injectors do you recommend for the best performance?
is a stock fuel pump ok for high performance gt injectors?
jimc_65 is offline
post #8 of 22 Old 09-01-2008, 06:00 PM
HeepToJeep
1982 CJ8
Originally Posted by jimc_65 View Post
heep...i plan on installing a cold air intake too. I was going to buy 19lbs. mustang gt injectors. Will they give me significant HP and performance improvement? What injectors do you recommend for the best performance? is a stock fuel pump ok for high performance gt injectors?
Your stock injectors run at 18.6lb/hr and only have two holes in the injector discs, the upgrades are 19lb/hr and have four smaller holes in the injector discs. The slightly higher fuel pressure doesn't do nearly as much as the four smaller holes in the discs because they send more of the fuel into the cylinder fully atomized (as a vapor which burns better). Unless your current injectors are shot you aren't going to notice a huge difference but you will be able to tell there's a faster throttle response, smoother running and a little better fuel milage.
Your stock fuel pump will work fine with the 19lb/hr injectors as they aren't dumping a lot more fuel into the engine, they're simply making better use of the fuel it was already getting. Regardless of which brand of injectors or 'donor vehicle' you decide on it's not going to make a difference as they're going to be 19lb/hr and have the four hole discs.....I tried both the yellow top Bosch and gray Ford injectors and was unable to tell any difference at all between them.
When I caught wind of this 'possible upgrade' instead of shelling out big bucks for new injectors on a maybe I went and grabbed some good ones from the boneyard to experiment with....cheap, plentiful, easy to pull and you can tell right away if the injectors are old as the heat and fuel discolors them with age.
Wm
post #9 of 22 Old 09-01-2008, 06:09 PM
Toliver09
1991 XJ Cherokee
Could running 24 lb injectors cause problems in a 92 cherokee? I have a set sitting here that i bought just for the jeep, but have no idea if I will be able to do this without going to a high flow pump
98% of drivers say "oh crap" when they see snow, the other 2% are Central Illinoisans that say "Hold my beer and watch this!"
Toliver09 is offline
post #10 of 22 Old 09-01-2008, 06:15 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
'91-'93, ........33007127, ...Brown, .......39psi, .................21.0lb/hr
24 will be too rich.
Factory Four Link
XJLI is offline
post #11 of 22 Old 09-01-2008, 06:17 PM
Toliver09
1991 XJ Cherokee
what if I ran a bored out tb, high flow intake? I can get my pcm reprogrammed for next to nothing if I had to just to make it work
post #12 of 22 Old 09-01-2008, 06:26 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
im running a cowl intake, bored tb, apn header, hi flow cat, and hi flow muffler and havent had a problem with running lean. reprogramming the ECU isnt worth it IMHO. look into an adjustable MAP if anything, thats one of the next thing on my list.
http://go.jeep-xj.info/HowtoMAPsensor.htm
Factory Four Link
XJLI is offline
post #13 of 22 Old 09-01-2008, 08:20 PM
HeepToJeep
1982 CJ8
If you're really interested in tweaking a 4.0 I strongly suggest going to the following page, I've turned the web upside down and have never come across one single source that offered as much GOOD information as Dino offers.
http://www.jeep4.0performance.4mg.com/index.html
Wm
post #14 of 22 Old 09-01-2008, 08:36 PM
tangofox007
Why? Wouldn't an increase in volume be offset by a shorter duty cycle?
tangofox007 is offline
post #15 of 22 Old 09-01-2008, 08:49 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
wheres the 'you have surpassed my knowledge of motors' smiley?
Factory Four Link
XJLI is offline
Mustang injectors? jeepnphreak XJ Cherokee Technical Forum 21 12-21-2010 07:34 PM
mustang 5.0 injectors on a 98 jackdup XJ Cherokee Technical Forum 3 09-24-2009 12:12 PM
mustang injectors jeeptorino68 XJ Cherokee Technical Forum 2 09-12-2009 05:45 AM
Mustang Injectors SID297 XJ Cherokee Technical Forum 20 09-05-2007 03:05 PM
What Mustang Injectors will fit my 98 4.0? TheEddie XJ Cherokee Technical Forum 6 06-07-2007 10:18 AM
