Multiple Misfires - Check Engine Light - JeepForum.com
post #1 of 13 Old 06-11-2012, 11:02 PM Thread Starter
noxj
I may need a mad scientist here. Check engine light has been on for a couple of days. Code was 1-3-5 misfiring. So i changed the spark plugs. Still had the light and the same code. Changed the coil pack (its an 01) and the light is still on.
Also There is a hint of a fuel odor when i first start it up. At first I was thinking this was a surge in pressure from the pump at start up so I checked my fuel lines. All the connections under the hood were fine and that's where the smell was coming from. That led me to the EEV filter and it was clean.
So now what I'm thinking is I have two problems. My temp gauge is clogged up or my fuel filter is clogged. Maybe there is also a crack in my exhaust somewhere letting out the unburnt fuel from the misfires?
Anyone have any experience this far in the ignition system?
Thanks in advance
-Noah
noxj is offline
post #2 of 13 Old 06-11-2012, 11:26 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Exactly what CEL codes did you download ? When exactly, and under what conditions, is it mis-firing ? What brand and part number spark plugs did you install ?
If you smell fuel under the hood, you have a fuel leak. Check the fuel rail, the fuel lines, and the injector o-rings.
CJ7-Tim is offline
post #3 of 13 Old 06-12-2012, 04:58 AM Thread Starter
noxj
I didn't save the receipt from autozone so I don't have the code. If it is still lit after I change temp gauge and fuel filter I will save receipt. The temp gauge was a little foul when I pulled it last night so I will see if that turns out to be my problem.
It is misfiring at idle, but I'm not convinced that is is consistent. I feel like it has the power that it should while accelerating, so I know that its not missing half the cylinders (1,3,5 were reported by the comp.)
As far as plugs they were autolite coppers. Nothing fancy as I know the 4.0 prefers cheap plugs. These were in the Napa computer system.
Ok will check on the fuel leak, thank you very much
-Noah
noxj is offline
post #4 of 13 Old 06-12-2012, 10:48 AM
CJ7-Tim
CJ7-Tim's Avatar
The Jeep in-line 6 cylinder has never been known for smooth idling. If it idles at 600-800 rpm's, and doesn't stall, it is fine. AutoLite copper plug should be OK. I prefer NGK or Champion copper or the AutoLite APP-985 for the 2000+ 4.0L.
CJ7-Tim is offline
post #5 of 13 Old 06-12-2012, 11:01 AM
buildin1XJ
Just wondered if one of the codes pulled was a random cylinder misfire,or just the three you mention. If you smell fuel in the engine bay like Tim said you must have a leak. Maybe the fuel injectors o rings for just those three cylinders.
buildin1XJ is offline
post #6 of 13 Old 06-12-2012, 05:36 PM Thread Starter
noxj
Haha yeah true that. In that case it is idling just fine.
The individual codes were:
-P0301
-P0303
-P0305
I think you're thinking along the right track. For each of the three codes, the readout was as follows:
--Definition
--Cylinder misfire detected - cylinder number 1,3,5 (for each individual code, stating for clarity)
--Explanation:
--the powertrain control module monitors the crankshaft speed and has detected a misfire condition
--Probable Cause:
--Ignition system fault - spark plugs, ignition wires, coil ****new everything so this is not answer unfortunately
--Vacuum Leak
--injector fault
--high or low fuel pressure
I'm still thinking the fuel smell and the misfires are related so I will check injectors. In fact, I know the fuel lines themselves aren't leaking and I was at a dead end there. Hopefully I can update with good news but if anyone has any ideas or experiences to share that would be great. Thank you both
-Noah
noxj is offline
post #7 of 13 Old 06-12-2012, 05:42 PM
CJ7-Tim
CJ7-Tim's Avatar
Here are some generic Jeep misfire causes. I would add a bottle of fuel injector cleaner to the next 2-3 gas tank fill-ups.
Possible causes
- Faulty spark plug
- Faulty ignition coil
- Ignition coil harness is open or shorted
- Ignition coil poor electrical connection
- Clogged or faulty fuel injector
- Injector harness is open or shorted
- Injector poor electrical connection
- Improper spark plug
- Insufficient cylinder compression
- Incorrect fuel pressure
- Intake air leak
CJ7-Tim is offline
post #8 of 13 Old 06-12-2012, 05:49 PM Thread Starter
noxj
Possible causes
- Faulty spark plug
- Intake air leak
Thanks Tim I will add these to the check list.
-Noah
noxj is offline
post #9 of 13 Old 06-12-2012, 05:55 PM Thread Starter
noxj
Also how terrible is it that I'm dumping all this unburnt fuel into my cats? I'm forced to drive it 6 miles a day, I really don't have another option. I doubt it will be many more days before I hunt this thing down. Just wondering thank you
-Noah
noxj is offline
post #10 of 13 Old 06-12-2012, 06:09 PM
CJ7-Tim
CJ7-Tim's Avatar
If the fuel smell is under the hood you probably have a leak, if the fuel smell is at the exhaust pipe you probably have a drippy fuel injector. The amounts of fuel in either case is a few drops. The misfires are not constant so you might be 1/4 of 1% (0.025 %) less fuel efficient.
CJ7-Tim is offline
post #11 of 13 Old 06-12-2012, 11:05 PM
theguywithjeeps
1989 MJ Comanche
go to the fuel pressure regulator at the front of the fuel rail and pull the vaccume line. if gas comes out the regulator then that is your problem. it was mine. also make sure your codes are cleared after you replace somthing
theguywithjeeps is offline
post #12 of 13 Old 06-13-2012, 12:49 AM
justanotherjpr
Its probably injector heat soak. Try hood vents, a e-fan switch and/or the heat wrap for your injectors. I had to use all three.
justanotherjpr is offline
post #13 of 13 Old 06-13-2012, 09:39 AM
CJ7-Tim
CJ7-Tim's Avatar
Later OBD-II Cherokee do not have this.
At startup, the engine management is in open loop, and mis-fires due to heat soak, drippy injectors, or a faulty check valve don't trigger a CEL.
CJ7-Tim is offline
fuel leak , ignition , spark plugs , temperature gauge
check engine light on 2000 cherokee.. can i check it my self? Magic2979 XJ Cherokee Technical Forum 27 12-11-2013 09:46 AM
Multiple random misfires, misfire 1, 3 mattathayde XJ Cherokee Technical Forum 6 05-23-2009 04:47 PM
96 Grand Cherokee Limited- Check Engine Light indicates Misfires Adoniram XJ Cherokee Technical Forum 2 12-15-2007 11:19 AM
Misfires & Check Engine Light philodendrin XJ Cherokee Technical Forum 3 09-02-2007 12:10 AM
'96 XJ multiple misfires briansxj XJ Cherokee Technical Forum 2 06-11-2007 07:01 PM
