Muffler size? - JeepForum.com
post #1 of 9 Old 09-21-2009, 12:59 PM Thread Starter
orangepower1987
1993 XJ Cherokee
Muffler size?
Hey I'm about to get a muffler and put that sucker on my 93. How do you determine the size of the muffler you need (showing my inexperience here). I would like to do it myself, but I want to make sure I get the right size. What else will I need other than the flowmaster offroad with the right size? Should I just leave it without a pipe and drop it? Any help would be great!
93' XJ Cherokee DD "White Lightening"
orangepower1987 is offline
post #2 of 9 Old 09-21-2009, 01:14 PM
Luke94XJ
1994 XJ Cherokee
well that depends on the size of exhaust you have right now, most are going to be 2.25" that will most likely work, are you going to weld it up? otherwise you will need muffler clamps. you may need a sawzall, but most likely a good beating hammer to remove your old muffler. after that its a matter of beating on your new muffler and clamping it down.
Luke94XJ is offline
post #3 of 9 Old 09-21-2009, 01:18 PM Thread Starter
orangepower1987
1993 XJ Cherokee
I just have the stock in there right now. I don't plan on welding, I can see catastrophe there. I can get a sawzall but I'm pretty good at putting alot of pissed-off behind a hammer. So once i clamp the new muffler to the old pipe coming from the motor, I can just leave the exiting hole the way it is?
post #4 of 9 Old 09-21-2009, 03:51 PM Thread Starter
orangepower1987
1993 XJ Cherokee
For example, should I leave the tail pipe or dump it? Is the stock exhaust pipe ok to clamp and leave it?
post #5 of 9 Old 09-21-2009, 10:24 PM
Luke94XJ
1994 XJ Cherokee
oh the choice is up to you, you can get a cool sound having no tailpipe, but the tailpipe will direct gasses away from the undercarriage, so that it doesn't smell when idling .
Luke94XJ is offline
post #6 of 9 Old 09-21-2009, 10:35 PM Thread Starter
orangepower1987
1993 XJ Cherokee
Ok thanks Luke. Should I leave my exhaust pipe to the muffler the same or should I change it?
post #7 of 9 Old 09-22-2009, 07:47 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
2.25" does just fine.
If you plan on running a tail pipe, the XJ type will be center in and offset out. That should give you close enough to stock to still use the factory hanger locations without issue.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #8 of 9 Old 09-22-2009, 08:33 AM
Jeepy84
If you intend to ditch the tailpipe, you may want to dump it out the side instead of letting it out underneath, my $.02
"Hello people, would you like me to murder you now? I'm an offroad enthusiast."
"His station wagon is more Jeep than your topless minivan."
Jeepy84 is offline
post #9 of 9 Old 09-22-2009, 09:10 AM Thread Starter
orangepower1987
1993 XJ Cherokee
Awesome! Thanks everyone. I'll probably buy the super offroad FM, clamps, and turndown tip and see how it sounds!
Any got the socket size + torx screw size list? willcherokeexj XJ Cherokee Technical Forum 5 05-19-2009 11:23 PM
doing shocks tonight. need bolt size and nut size toates89 XJ Cherokee Technical Forum 1 01-14-2008 05:28 PM
size of muffler 88wagon XJ Cherokee Technical Forum 5 12-30-2006 08:24 PM
D44 brake drum size/ shoe size Timo_90xj XJ Cherokee Technical Forum 4 12-05-2006 07:32 PM
what size muffler Cherokee-Dan XJ Cherokee Technical Forum 2 09-16-2003 05:55 PM
