Quantcast Mud and CB Install Pics - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Mud and CB Install Pics
Old 04-02-2006, 06:42 PM   #1
Grand Fan 4eva
went to some mud runs yesterday and had a great time but the clean-up today consumed at least a few hours and i found mud in places i didnt think possible ha ha. It was worth it showing up those guys in the full-size pick-ups though these pics are after driving home id the mud too...
Before:
After:
and here's my overhead CB install: same idea as the rocklizard fab but i used aluminum diamond plate instead.
TORQUE... An Underrated Anti-Depressant.
'97 Cherokee ~6.5" / 33 trxus / RK 3-link
'91 Comanche stock/4.10's/ 31's
Grand Fan 4eva is offline   Reply With Quote
Old 04-02-2006, 06:49 PM   #2
LEAD_NOT_FOLLOW
1989 XJ Cherokee
Holy I'd have those lights crushed by a tree on the trail batman....
LEAD_NOT_FOLLOW is offline   Reply With Quote
Old 04-02-2006, 06:50 PM   #3
creature
Did you make that CB mount yourself? Looks good
-Shawn
creature is offline   Reply With Quote
Old 04-02-2006, 06:53 PM   #4
gwarusee
The "mud mod" seems like a hard one. How did you go about performing it
Cool job on the cb instal. CB and a winch are on my to do/to need list.
gwarusee is offline   Reply With Quote
Old 04-02-2006, 08:07 PM   #5
Jayhawk077
i like the slits you have in your grille. did you paint them silver or are they chrome inserts?
Jayhawk077 is offline   Reply With Quote
Old 04-02-2006, 08:15 PM   #6
SlimGoaty
SlimGoaty's Avatar
1997 XJ Cherokee
Chrome Door trim, Its and cheap and easy mod.
2002 WJ Laredo 4.7
97 XJ 4.0 AW4 150k
Harness Upgrade, PIAA intense white bulbs.
Soon to have 6.5LA and 33x12.50
97 ZJ 5.2 Limited 144k
31x10.50 MT's
Flowmaster Super 44 (http://www.youtube.com/watch?v=pzi9wYMGpVU)
Originally Posted by greasefingers
I never trust gauges or midgets from Sweden.
SlimGoaty is offline   Reply With Quote
Old 04-02-2006, 08:18 PM   #7
Jayhawk077
where did you buy it?
Old 04-02-2006, 08:54 PM   #8
Jeepernick
2008 XJ Cherokee
so you installed that mud??
I normally just install the CB and then go and play in the mud, you know drive in the mud
Jeepernick is offline   Reply With Quote
Old 04-03-2006, 06:10 PM   #9
Grand Fan 4eva
Actually, i've just been waiting for that to happen but i go wheeling at least every weekend and with a little thought i've been able to drive away unscathed every time
Thanks. all i did was make a paper template and cut the aluminum to the shape. Then i marked the visor holes, drilled them out and pre-drilled the holes for the screws on the cb bracket. I finished it off but cutting off the screws sticking out the top and re-installing the visor clips.
BTW- do you guys think its absolutly nessecary to change my diff fluids? the mud was very soupy and watery in a few spots and was most likely above my axle tube/seals and bearings. i've hosed down the underdside pretty well and blasted the mud out of most of the nooks and crannies, are there any other things that i should/need to do?
Thanks
Old 04-03-2006, 06:40 PM   #10
creature
Thanks
Open the fill hole, dip your pinky in and look to see if the gear oil looks off (like chocolate milk).
don't worry if it smells bad, thats how it is supposed to smell
-Shawn
Old 04-03-2006, 07:44 PM   #11
Grand Fan 4eva
What about my wheel bearings and bearings in the axle tube? if the nasty mud made it to the pumpkin it would have had to gone through a few bearings too
Old 04-04-2006, 06:07 PM   #12
Grand Fan 4eva
nobody has any other suggestions as far as bearings go?
Glock Forum
